Re:Coloseum From 2003
Post by William » Thu Oct 30, 2014 6:58 am
Thank You Feymous, I really enjoy viewing your beautiful scenes.
Here is an oldie and it's map. I always wonder how others keep a record of layouts, I used to draw them on graph paper after the final design. I haven't had the space to build one in years, but hope to soon with all the Caverns coming in a few weeks.
The layout picture is very washed out, but the map looks O.K.
Thought I would toss out this map of a layout, I will eventually post on another thread.
EDIT: Pictures Fixed
Feymous
Post by Feymous » Sat Oct 25, 2014 11:24 am
William,
I haven't been on the forums much this past month and then I log on to discover this thread. I don't even know where to start...there's enough DF goodness on these pages to fill 3 or 4 threads :) The colosseum is epic, really unique and creative uses of the basic dungeon pieces. Your cavernous sculpt is beautiful and atmospheric, great place for an adventure. Finally, your method for creating water tiles is brilliant. I'm shocked that you got such great results from such a simple technique. I must try that.
Thanks for sharing!!!
Post by William » Wed Oct 22, 2014 3:40 am
Here are two more pictureswith the water effect sheets and large roll shown in background.
Most of the terrain was custom done 13 years ago along with the pictures.
Post by William » Tue Oct 21, 2014 11:09 am
Thank you Biowizard that means a lot from you. :-)
It's very easy to do. I will post a few pictures showing the effect in several layouts.
I have some letter size sheets of a grid pattern I found somewhere and scaled them to be the right size. They are the grid that looks tiled below, the pdf or jpg was black and white but shaded for texture. I have about a dozen burried in my basement I have to find. Anyway, just get some celophane wrapping paper of blue, red, green or any other color and lay it over the grid sheets. I made up some with a tiny bit of tape holding the corners together so I can just spread them out. As you will notice in some of the larger areas I just did a Sharpie squiggle line on a roough 1" grid and layered green then blue over that. You could do reds, orange, yellow or any combo for slime or acid. Try Joanne Fabric, Michael's, any gift store selling wrapping paper that is see-through. Like I said, It's easy.
Section C.JPG (143.92 KiB) Viewed 3219 times
Post by biowizard » Tue Oct 21, 2014 10:30 am
Could you tell us precisely how you made the lake? It's beautiful.
Post by William » Tue Oct 21, 2014 8:41 am
Here are more close up shots of the Tomb/Cave Entry area.
A1 HPIM2704.JPG (85.88 KiB) Viewed 3212 times
A2 HPIM2703crop.jpg (105.09 KiB) Viewed 3212 times
A3 HPIM2702crop.jpg (125.78 KiB) Viewed 3212 times
A4 HPIM2701crop.jpg (181.05 KiB) Viewed 3212 times
B1 HPIM2699crop.jpg (284.09 KiB) Viewed 3212 times
B2 HPIM2691crop.jpg (310.27 KiB) Viewed 3212 times
C HPIM2734crop.jpg (304.16 KiB) Viewed 3212 times
D HPIM2713.JPG (143.09 KiB) Viewed 3212 times
Next time, the coloseum details. :-)
Post by William » Tue Oct 21, 2014 8:37 am
I lied, I found this burried in a deep dark folder. It's the Entry into the large cavern where the large lake and the Castle/Mansion and Coloseum are far beyond.
This is the Tomb/Cave Entry set-up. We got to play some of this back in the day before my probs. The cavern portion past the small lake was nixed because that little lake turned into a huge lake once the story was defined. Anyway, the first three pictures are of the area that was discarded, but I thought I would include for the fun of it. The little lake in pictures 4 through 6 was adjusted beyond lake. The portion before lake (the bottom of picture, closer to camera)was maintained as it is shown. The overall layout was about 13' long and 3' wide (2 doors end to end), but then was shortened ny 3 or 4 feet.
The large lake was played off a small map and the day they found the other side where the Coloseum is, was the last time I gamed with a group. I did do a little DMing with a good friend and his kids a few times after that, but that became to difficult as time went on. Sob Sob, sorry I'll get off that horse now. Io the pictures.
E1 HPIM2717.JPG (136.81 KiB) Viewed 3214 times
E2 HPIM2723crop.jpg (267.13 KiB) Viewed 3214 times
A5 HPIM2739crop.jpg (269.67 KiB) Viewed 3214 times
Post by William » Tue Oct 14, 2014 3:51 am
Here is the last group of pictures of the Castle/Mansion layout. I never finished the final design.
I will be posting more pictures of the Coloseum and Tomb/Cave Entry in the future. That will finish the whole scenario of the part of my world I did finish (or close to it). I didn't want to call the thread by my world name because the coloseum was the highlight at the point I stoped working on it.
A place to feed guests with bar and kitchen behind -
Dining r01 HPIM3945clean.jpg (96.95 KiB) Viewed 3089 times
HOT TUB time (nooo) -
Cooks family quarters above -
Another of Entry from above -
The (un)finished design -
Next time will be more of the coloseum (tighter pictures with some minis).
Post by jchunick » Fri Oct 10, 2014 10:54 am
William Jacobs wrote:
Thank you Josh, that is so cool. You're so nice to do that.
I wanted to do that with my coloseum build and made a horid video that didn't work very well.
Thanks again, Bill
My pleasure! :-)
Post by William » Fri Oct 10, 2014 10:36 am
Thanks again, Bill
