Elevation pieces
Re: Elevation pieces
Post by AnimeSensei » Thu Jul 25, 2019 6:00 pm
Cool idea, Dinah! Thanks!
D DMs DnD
Ikea TJENA and GRÅSIDAN paper desk organizers as elevation
Post by D DMs DnD » Thu Jul 25, 2019 5:53 pm
Only a really silly person would bring a few DF pieces to Ikea with them just in case, but the silly bird gets the worm or something like that. :D
Tjena elevations.jpeg (66.22 KiB) Viewed 5459 times
Full walk through of the different TJENA set pieces here: https://medium.com/@metagrrrl/d-dms-d-d ... 7e87daf1bd
Looking forward to getting my hands on the GRÅSIDAN set to confirm it works, because it's in 2" dimensions and should give even more options.
Dinah
Post by Vegomatic » Fri May 24, 2019 12:08 pm
If you are looking for some different stairs the castle stair pack is another good one.
Gargs454
Post by Gargs454 » Fri May 24, 2019 11:42 am
The easy solution is to just win the lottery. :)
Going to take a look at my current diases and see how many more I want for extra "non-epic" stairs, but that and at least one more epic stairs set seems to be a good place to start! Of course, I want more floors and walls too so . . . lol
Post by Rabbit Burner » Wed May 22, 2019 5:20 am
Gargs454 wrote:
Tue May 21, 2019 10:43 am
That's a lot of monsters! I like your style. :D
Seriously though, these are all great ideas and gives me the inspiration I need. I still will want some of the transition type pieces (stairs, diases, ramps, etc.) but I don't necessarily need them all at once, or as much as I was thinking. This does give me a little more flexibility in choosing what to get since there are a number of other things I want to pick up too.
Yes regardless how you elevate parts of your build you still need ways to get up to them, so daises and grand stairways do the trick very nicely.
In fact DF provide many ways to do this from dedicated Stairs (CBS and Castles) to Grand Stairways to daises, elevation blocks and small stairs to CD Rising walls
Mitch
Post by Mitch » Tue May 21, 2019 7:12 pm
zenako wrote:
Mon May 20, 2019 4:03 pm
The other thing you can watch out for is packing foam. Many times it ends up being really close to 2" thick and you can use it instead of boxes and being a plain color would be less distracting. I keep an eye open for the trash at work from various incoming shipments and grab foam that looks like a good match. If it not, then I can just toss it with no money wasted on my end. That is what makes the foam Blocks that our Japan-based friend uses so attractive to folks, basic color, very modular and relatively inexpensive. Most foam from locations around the US does not have the nice dimensions his blocks come with.
I went with the packing foam option. Someone gave me a stack of 1 inch thick sheets they had found and which were just going to be chucked out. I cut them into 10x10 inch and 10x5 inch slabs (yes, I like my grids!) and then glued two slabs together giving me 10x10x2 and 10x5x2 elevation blocks. I then bought some thin sheets of card, cut it into 2 inch wide strips and glued these around the blocks to stop the edges from being broken. You could use cereal boxes for the card but I wanted strips I could wrap round the whole block and only have one seam where they met (yes, picky that way!). I then got 1L of black acrylic paint and used a small paint roller to paint the entire block. Total cost was A$5 for the card and $10 for the paint. The other stuff was free of I had it already (craft knife, cutting board, PVA glue and partner who doesn't mind her half her dining room being used as my craft workshop). ;)
ForestZ
Post by ForestZ » Tue May 21, 2019 1:12 pm
zenako wrote:
Tue May 21, 2019 9:00 am
Even for dungeon stuff using nonDF stuff to gain elevation can be a workable solution. In the picture below, I have a sheet of plexiglass supported by 4 or 5 USPS Priority Mail boxes had available, and you can see some packing material cardboard supports for some towers on a small hill in the background.
This reminds me of those original Doom levels, where all the monsters were stored in hidden rooms that open up and belch them forth when you trigger something, haha.
Gargs454
Post by Gargs454 » Tue May 21, 2019 10:43 am
Post by zenako » Tue May 21, 2019 9:00 am
Necro Warehouse Overview
Necro Warehouse Overview.jpg (100.54 KiB) Viewed 4566 times
Gargs454
Post by Gargs454 » Mon May 20, 2019 4:45 pm
Agree on the diases. I already have a set each of the straight and curved. Will likely pick more up as time goes on. GT and Acid Bath were both on my wish list too. Frankly, most of the stuff is lol. That said, I really only have a coupe hundred (might be able to stretch to three) to spend right now, so trying to get the most mileage for my money. Of course, I also love the caverns (which I have none of and couldn't do the KS as I had just bought a house which necessitated a lot of other purchases) and even the city stuff. *Sigh* Why does DF have to make such awesome stuff? :lol:
Regardless, I'm going to focus on the dungeon stuff for now I think so that I can have a nice variety there, then probably switch to working on caverns, etc. I do appreciate the replies though as they are really helpful. The one good thing is that the size of my builds will currently be somewhat limited by necessity as I currently travel to my games, so need something that can be put together fairly quickly -- terrain trays should definitely help with that.
