CBS, Large building, roofs?
Glendel
Re: CBS, Large building, roofs?
Post by Glendel » Wed Sep 26, 2018 5:36 pm
Possibly, It would be neat to have 1 large roof for our Inn.
Post by AnimeSensei » Wed Sep 26, 2018 3:37 pm
Glendel wrote:
Wed Sep 26, 2018 3:14 pm
Anyone know if this guy is still making those roofs?
His email is on the page: billyboy44@yahoo.com
http://www.dwarvenforge.info/toits/toits.htm
Worth a shot?
Glendel
Post by Glendel » Wed Sep 26, 2018 3:14 pm
Post by Rabbit Burner » Thu Aug 23, 2018 7:12 pm
jasdotcom wrote:
Thu Aug 23, 2018 2:22 pm
I have a set of these roofs and they were made to order, meaning I chose the dimensions and which would have the Tudor or stone look. I don't believe the creator is making them anymore though
Nice build :)
Will have to relook at the website, see if they do a bespoke option.
jasdotcom
Post by jasdotcom » Thu Aug 23, 2018 2:22 pm
Wed Aug 22, 2018 11:29 am
Fri Aug 17, 2018 1:00 pm
Have you thought of these?
Beautiful roofs, but even with the stone advanced builder set from Castles its no possible to create 6x6 or 10x10 buildings :(
Here is hoping for more adv builder options and some big old roof options
Post by zenako » Thu Aug 23, 2018 11:43 am
Definitely would be interested in a pack of items to facilitate two story internal spaces and walls with tall posts and spacers. Only way to get them now is as a part of a much larger (and out of stock) set.
Post by Rabbit Burner » Wed Aug 22, 2018 1:40 pm
MrMorden wrote:
Wed Aug 22, 2018 1:31 pm
Vegomatic wrote:
Wed Aug 22, 2018 1:26 pm
Two walls will work...but there will be a gap at the top without the riser... the riser is the thickness of a floor that would between the stacked walls.
I assumed that the posts were the height of two walls, not two plus a floor. Hmm...I'm sure I could make such a thing if needed. It would even be made to look like a fancy trim piece just under the roofline.
We raised this in a castle thread somewhere - The posts are high enough and you get the 4" riser but not the two inch riser for each end.
and here it is :)
viewtopic.php?f=48&t=8715
Post by Rabbit Burner » Wed Aug 22, 2018 1:36 pm
nielsene wrote:
Wed Aug 22, 2018 11:49 am
Yes I'm sure the extra inch all around is intentional. So they are roofs for free-standing 4x4s and 8x8s, which are useful, just not what I'm looking for.
OK - we will wait for someone else to do this first then, not sure we want the designed overhang and then another inch - as that's how we read the roof sizes ;)
liking the idea of roof triangular frameworks and having roof tiles (say 4x4") which you add to the framework to give you bigger roofs.
MrMorden
Post by MrMorden » Wed Aug 22, 2018 1:31 pm
Post by Vegomatic » Wed Aug 22, 2018 1:26 pm
MrMorden wrote:
Wed Aug 22, 2018 1:24 pm
Rhizom wrote:
Wed Aug 22, 2018 1:02 pm
Double height posts are great! I want those, too! But we also would need some wall risers then, like the ones in the stone advanced builder set, in order to match the correct wall height.
I don't think you need anything new for the walls. Two wall sections stacked one atop the other between two double height posts should work great.
