how do you dissolve the glue on dwarvenite?
Riley
Re: how do you dissolve the glue on dwarvenite?
Post by Riley » Thu Jan 03, 2019 7:36 pm
Black dragon breath might do the trick... but there may be scatter damage.
Post by zenako » Thu Jan 03, 2019 10:05 am
Depending on the piece you could soak it in hot/warm water to soften the glue and then remove it. (Do NOT do this for parts with electronics or magnetic components.) Depending on how it looks, make some lemonade out of that lemon with the extra glue feature and turn it into slime or mold on the part with a little paint or ink.
LordDarkhan
Post by LordDarkhan » Wed Jan 02, 2019 10:22 pm
I second this. I had a warped piece and told me how to unwarp it. They also said that if it didn't work, they'd replace it. They're very good about getting back to people.
Post by AnimeSensei » Thu Oct 18, 2018 4:01 pm
If you can't get it off, email customersupport@dwarvenforge.com
thelonegoldfish
Post by thelonegoldfish » Thu Oct 18, 2018 3:49 pm
One or two of the pieces from my order have glue on the outside of them. is there a recommended way to remove this?
