Magnetic Ideas for Game Tiles
TK 266
Re:Magnetic Ideas for Game Tiles
Post by TK 266 » Sat May 11, 2013 1:34 am
the Dwarvintie material is said to be similar the the material in a rubber mallet. by the looks of the durability video it should be able to be drilled into quite easily. as for the resin products, i am not sure.
the magnet idea sound good. let us know how it works out
Order 66? Isn't that the Kung Pao Chicken?
galahad
Post by galahad » Sat May 11, 2013 12:11 am
Drapes? Oh, you mean material for flaming arrows!
Good idea!
Pontifex Maximus of Valoria
301 Dwarvenite/132 Resin
Duncan_and_Dragons
Post by Duncan_and_Dragons » Wed Apr 17, 2013 8:51 pm
First idea - Magnets near the window frame. They can be used to hold shutters on the outside and drapes on the inside.
Duncan_and_Dragons
Post by Duncan_and_Dragons » Wed Apr 17, 2013 8:44 pm
I think the Game Tiles should be easier to modify. Hopefully so easy that I can drill small holes (2mm or 3mm) and insert magnetic cylinders in the walls. This in turn woulds make it easy to have items such as shields, pictures, tapestries, rack of weapons, etc. that should be pretty stable when mounted and easy to swap.
Anyone know if the material can easily be drilled? I imagine the hole would be a little rough. Would I even need to glue magnets in or would friction hold the magnets in place?
