Is this normal? What can I do?
Re: Is this normal? What can I do?
Post by geekjeff » Sat Apr 11, 2015 12:44 am
If you're thinking white with "snow glitter" I'd give one a try first with just slightly watered PVA glue (aka plain old Elmer's glue) and sprinkle your glitter/flock/etc on there like you're basing a mini.
It should hold fairly well, and if you don't end up liking it can be softened and removed pretty easily with water. A short water soak shouldn't bother the underlying resin or the surrounding lacquer based paints a bit.
Post by jackattack » Fri Apr 10, 2015 10:48 pm
Does anyone make a fine wire brush that would fit in there?
Post by AnimeSensei » Fri Apr 10, 2015 9:26 pm
Extra fine sandpaper could work too.
Post by LordDust » Fri Apr 10, 2015 4:23 pm
nararabbit wrote:Hi Biowizard,
I did let Suzy know about your set as well. They will be checking their other sets for this. My husband and I decided to paint the yellowed clear areas, either white with "snow" glitter, or possibly blood. (Probably the white!) Now to get some Pokorny paints in white, I hear it is the best around..! Any hints for getting the paint to "stick" to the glossy resin? Sanding in such tiny crevices would be quite challenging. I am wondering if a chemical or acid such as lemon juice could do the work...
I would probably try to gently rough it a bit with a dremel on low speed. If you aren't used to using one practice a bit on something less dear first. That should be a quick and relatively easy way to rough the surface a wee bit. Otherwise you could use a resin and paint friendly adhesive over it in a thin layer almost like a primer.
nararabbit
Post by nararabbit » Fri Apr 10, 2015 2:48 pm
Hi Biowizard,
Post by biowizard » Thu Apr 09, 2015 11:02 pm
My Ice Cavern Resin Set also turned yellow, the parts with the deepest clear resin recesses. I'm pointing it out not because I want to have my Set replaced but as I suspect that most if not all Cavern resin Set probably behaved this way after a few years and DF should know that the factory's choice of clear resin brand should/could be adapted in future projects.
Post by LordDust » Thu Apr 09, 2015 4:12 pm
That is odd... that sort of thing in resin is (according to what I understand) usually a chemical reaction triggered by exposure to energy (heat or light typically) or to another chemical. Glad they're helping you out.
dafrca
Post by dafrca » Thu Apr 09, 2015 4:09 pm
nararabbit wrote:Suzy @ Dwarven Forge is helping me now, so we can close this topic. But to answer the original question, it's not normal! :lol:
Glad to hear both that you are being helped and that it is not normal. :D
nararabbit
Post by nararabbit » Thu Apr 09, 2015 4:07 pm
nararabbit
Post by nararabbit » Thu Apr 09, 2015 4:01 pm
@Nikdo -
those areas of resin were clear and shiny, presumably to look like either water or icy spots. They've always been shiny. Not tacky or sticky to the touch thankfully.
