Axe N Shield Terrain Risers KS
Re: Axe N Shield Terrain Risers KS
Post by GardenDM » Sat May 04, 2019 12:19 pm
nielsene wrote:
Sat May 04, 2019 12:15 pm
Backing at the Hammered level, and adding on some 4" risers. Looks like the closest "off-the-shelf" versions of the acryllic risers Overlord? used with such amazing affect. Not sure I need all the smaller pieces... will re-asses if they look close to funding and swap stuff around.
But this doesn't have angled ramps, right? For strict elevation builds, foam blocks work pretty well. This seems more oriented for magically floating areas? Or am I being short-sighted here?
Post by nielsene » Sat May 04, 2019 12:15 pm
Post by GardenDM » Sat May 04, 2019 11:49 am
Thoughts on this one? I'm currently in for an early bird Core Set, but am eyeing the Estate Set for the bridge pieces. Not sure if I can add those to my existing Core pledge.
https://www.kickstarter.com/projects/ax ... escription
