Three by Three tiles?
Re: Three by Three tiles?
Post by Rabbit Burner » Thu May 23, 2019 2:32 am
Very cool :)
Always heard rumours of the Crystal Gravel pit dimension. Looks like they could make awesome Rabbit holes, if a little hard on the fur.
Post by Oldent » Wed May 22, 2019 11:56 am
I have made one two inch deep geode tile in 3" by 3"
Post by Oldent » Wed May 22, 2019 9:57 am
Thanks Everyone :!:
Wed May 22, 2019 7:42 am
I love the "stacked hole" with the crystals down the sides and wood bridge over the whirlpool. 8-)
I have to ask, will the gravel stay unglued, so the players can dig in it?
Then you could hide a prize inside. ;)
William I have not decided on the gravel. Cool idea about digging :D
With and with out the fire pit with the light panel.
I have tried different ideas with the crystal and stacked geode idea.The light panel may be best.
Post by dice4hire » Wed May 22, 2019 8:52 am
Truly excellent!! :!:
Post by William » Wed May 22, 2019 7:42 am
Post by Rabbit Burner » Wed May 22, 2019 7:31 am
Ahh wonders from Old Man Willows dimension of the 3rd inch, these are very rare and as you can see wonderous to behold, just be wary adventurer those that go into the 3rd inch dimension do not come out the same ........
Weltenlaeufer
Post by Weltenlaeufer » Tue May 21, 2019 7:30 pm
:shock: :shock: :shock:
Epic!
ForestZ
Post by ForestZ » Tue May 21, 2019 7:14 pm
Man, you always make such cool stuff! I had not considered the possibilities those holes in the SW Mines tiles presented. Love those gem encrusted shafts, and also the lighting options are great! Now I'm imagining some red light (and I wish I had a fog machine too) to imply some lava underneath. Brings to mind an Indiana Jones and the Temple of Doom vibe!
Post by Oldent » Tue May 21, 2019 6:48 pm
I have been using the tabbed passage walls quite a bit. I saw the need for some 3"By 3" tiles.Zombiecide Green Hoard and Massive Darkness are played in sections. I decided to use a 4" sections. The 3" tile surrounded by the tabbed passage walls is 4"
4 botcast and Lady Sabelle! cast
I had a mine shaft in mind. The grave and purple glass shards are not glued down.
I may use a geode style with this tile.
The glass shards were glued to the edge of the pink foam with glitter glue.
I had a mine in mind when I added the gravel.
Skulls, gold or crystals may work as well.
I have ordered some steel bases to make some mine tab walls. May be I should get some clear plastic for under lit tiles too.
