mine works
Re: mine works
Post by Oldent » Mon Mar 16, 2020 4:37 pm
A little more progress
Re: mine works
Post by Oldent » Mon Mar 16, 2020 12:23 pm
I was inspired by Nate's live stream. What if the void was large enough for existing LED crystals :idea: I have a hot wire cutter so I used some 1X4X4s to make a concept model.
I recalled I already have some 4X4X1s that would work.
The small void was too small.
I made a spacer from a 1X4X4.
I will be able to a just the thickness of the pink foam. This is a secret weapon tile I removed the bridge.
The spacers will work with the larger crystals too.
There are several options for the fog machine too. Remember to use water prof PVA
WIP photo of some extra floor tiles. I am going to add a violet interference dry brush. I need to pin the dragon wings so that they can be removed for transport.
Re: mine works
Post by Oldent » Mon Mar 16, 2020 11:39 am
Mon Mar 16, 2020 9:10 am
blakoutsun wrote:
Mon Mar 16, 2020 8:41 am
Every time I see a post of Oldent's work I wonder what I'm doing with my life and dream of one day becoming proficient in crafting...
We hear that, he is the Craft Master.
Those doors are awesome.
Thanks :!:
Re: mine works
Post by Rabbit Burner » Mon Mar 16, 2020 9:10 am
blakoutsun
Re: mine works
Post by blakoutsun » Mon Mar 16, 2020 8:41 am
Re: mine works
Post by Oldent » Fri Mar 13, 2020 6:52 pm
Fri Mar 13, 2020 6:35 pm
O.K., I was wondering. ;) 8-)
My first set of lily pads were made with Sculpey and worked just fine. Maybe a little brittle, but they are super light, so even dropping them doesn't really do anything. I did the Feymous set out of GS to give them a chance during play. I don't have others usually messing with my home stuff, so fragile is O.K.
I will use the sculpey to practice.
Re: mine works
Post by William » Fri Mar 13, 2020 6:35 pm
Re: mine works
Post by Oldent » Fri Mar 13, 2020 6:17 pm
Fri Mar 13, 2020 5:31 pm
Wait, did you bake the clay over the foam? :?: :shock:
No, I used the pink Foam as a template. The clay stamp was a little large.Using the foam template I trimmed the clay to the correct size.
I pressed the lion into the foam first. It did not leave a deep enough impression. It would look better if I painted the depressions.
The pink foam is also too light weight to support some of the metal decorations. The clay takes impressions better and is heaver.
I was thinking of using the oven baked clay to make some lily pads. I do not have any green.
Re: mine works
Post by William » Fri Mar 13, 2020 5:31 pm
Re: mine works
Post by Oldent » Fri Mar 13, 2020 3:26 pm
I made some mods for the Griffin Tamer Gate. I used oven baked clay and pink foam.
