3X3 vs 2X2 For water falls
Re: 3X3 vs 2X2 For water falls
Post by Oldent » Thu May 21, 2020 11:55 am
NiandoBG wrote:
Fri May 15, 2020 4:48 pm
The gate looks promising. :o
Did you cast the hand yourself?
Looking forward to see the end result. :)
The hands are Halloween decorations. I trim them and manipulate them with hot water.
I have some supports for the cave. I am going to make some new supports for a Necromancer draw bridge.
I am casting more components.
I need to paint them before I glue them together.
A gate with small hands. This version is wasteful of skulls I will do something different for the gate house.
This looks more like an owl than a skull. I will use different cast for the teeth and make the eyes round.
Thoughts :idea:
NiandoBG
Post by NiandoBG » Fri May 15, 2020 4:48 pm
Post by Oldent » Fri May 15, 2020 11:28 am
Gate WIP :?: :idea:
Post by Oldent » Fri May 15, 2020 8:28 am
I purchased these with the idea to use the ribs as prison bars
Thoughts :idea:
Post by Oldent » Fri May 15, 2020 8:25 am
Fri May 15, 2020 5:56 am
Thu May 14, 2020 7:19 pm
I am not sure how I want it to look. I have enough parts to try several things. :?
We have seen the jars *shivvers
Keep the pictures coming Oldent always a joy to troll through them - loved seeing your assault on Minas Tirith pictures again :)
I enjoy your wargame photos too :!:
Post by Rabbit Burner » Fri May 15, 2020 5:56 am
Post by Oldent » Thu May 14, 2020 7:19 pm
I am going to use a brass rod for the hinge. The hydrocal may have to be replaced with resin.
I am not sure of the form the pillars will take.
I think, I am going to bend the small fingers on the out sided to form a rail. The bone fingers support each other when they inter lock
Post by William » Thu May 14, 2020 5:11 pm
Wire hanger rod through the wrists into side pillars, back far enough that the back end will not hit when opening. Then make the thumbs be the locking brace somehow.
That should leave the fingers quite bouncy and fraught with danger.
Got a top down picture of side base units and a separate hand pic?
Post by Oldent » Thu May 14, 2020 4:42 pm
I am thinking about a necromancer bridge. I want to use it as a spell. I started think about converting it to a draw bridge too.
Ideas :?:
Post by Oldent » Thu May 14, 2020 4:19 pm
Thu May 14, 2020 3:56 pm
Looks good OMW. 8-)
Now that's a hat. 15 gallon? ;)
I am reorganizing
