Secret Weapon - Mines
Re: Secret Weapon - Mines
Post by Oldent » Fri Jul 13, 2018 9:39 pm
Very cool!
Post by pacarat » Fri Jul 13, 2018 8:57 pm
Great stuff there - still waiting on mine... :cry:
Riley
Post by Riley » Fri Jul 13, 2018 8:45 pm
Very nicely done, Sir William!
Post by William » Fri Jul 13, 2018 8:42 pm
A few more shots to show how it will fit into Cavern floor system.
The 'L' shaped 2x2's only needed minor shaving to fit DF floor tile. Instead of a permanent fill to those missing areas I was going to sculpt a filler then try to mold and cast the 6 I needed, but had some other cavern dwarvenite floor tile pieces I just cut into the other 5. I'll finish the sculpted one but just use in as the 6th.
SW 2x2 Filler Pieces 03.jpg (50.12 KiB) Viewed 1422 times
SW 2x2 Filler Pieces 08.jpg (51.97 KiB) Viewed 1422 times
SW 2x2 Filler Pieces 16.jpg (31.58 KiB) Viewed 1422 times
This is showing the green stuff done on the underside of walkway.
SW RW Base Coat 032.jpg (69.03 KiB) Viewed 1422 times
Here are a few quickie layouts for fun...
Cavern Walkway 01.jpg (44.81 KiB) Viewed 1422 times
Cavern Walkway 02.jpg (71.36 KiB) Viewed 1422 times
Skull Island sort-of.jpg (86.61 KiB) Viewed 1422 times
Post by William » Fri Jul 13, 2018 7:14 pm
Here are a few work-in-progress shots of what I'm doing to the raised walkways.
Three sets. I wanted them to look more like a Cavern rather than a mine, so I cut away some pieces and added other flourishes of mineral flows. I didn't want any repeat pieces, but the straight ones were tough to change.
While doing some Green Stuff additions..
SW RW GS Sculpting 008.jpg (43.35 KiB) Viewed 1419 times
A Specialty Piece I made from leftover pieces.
SW RW Specialty Piece 001.jpg (47.46 KiB) Viewed 1419 times
SW RW Specialty Piece 002.jpg (50.32 KiB) Viewed 1419 times
SW RW Specialty Piece 003.jpg (45.32 KiB) Viewed 1419 times
More of the base coating stage.
SW RW Base Coat 016.jpg (71 KiB) Viewed 1419 times
SW RW Base Coat 025.jpg (37.03 KiB) Viewed 1419 times
SW RW Base Coat 047.jpg (56.36 KiB) Viewed 1419 times
Post by Oldent » Tue Jul 03, 2018 9:40 pm
ced1106 wrote:
Sat Jun 30, 2018 3:26 pm
Fantastic job, Oldent!
How did you paint the tiles? I normally take the lazy way out with gray craft paint then Secret Weapon Stone Wash, but would like to know how to paint desert-colored tiles! Thanks!
I am not sure how I would do desert color. May be brown shoe polish but I am not sure it would stick :roll:
Glue
I used Gorilla brand super glue.
It worked well on the Orc cages and doors.
Post by William » Tue Jul 03, 2018 8:36 pm
I've been using super glue and also some green stuff work on the raised walkways and they both appear to work nicely. ;)
Riley
Post by Riley » Tue Jul 03, 2018 8:06 pm
I just received my mines!
Does anyone know what would be the best glue to use on these? The material seems to be a relatively stiff version of Reaper Bonesium.
ced1106
Post by ced1106 » Sat Jun 30, 2018 3:26 pm
seeamanaboutadog
Post by seeamanaboutadog » Tue Jun 26, 2018 10:42 am
Lovely paint job Oldent!
Bossman wrote:
Sun Jun 24, 2018 4:56 pm
How is the quality of the Fogou gypsum/resin? Cheers
Remarkable and whats more each piece is a separate sculpt, there is no multiples of a sculpt..
AKA Lughtegern Lord Of Mice.
