3D printed accessories for DF
Re: 3D printed accessories for DF
Post by HeroQuestFrance » Thu Nov 16, 2017 6:02 am
Good ideas !!!
Post by kitenerd » Tue Nov 14, 2017 12:46 am
ok that didn't work...
i'm thinking 3d print a groove/tray for prefab battery box/holder for hobby motor - then it is a slip together project and nothing will shift
Post by kitenerd » Tue Nov 14, 2017 12:40 am
simage4344 wrote:
Mon Nov 13, 2017 3:59 pm
In order to make the internal parts turn with the wheel, I would need to find a way to secure them to a floor piece somehow. One way is to try and utilize the floor pieces with the stairway hole.
just put a channel on the battery box that the wall slips into - then nothing can move - it will raise the wall ever so slightly, but shouldn't be too bad
attempt at ascii art
OOOO
OOOO
OOOO
XXXXXXXXXXXOOOO
l lXXXXXXXXXXXOOOO
l___lXXXXXXXXXXXOOOO
so the 000 is the motor, the xxx is the box for 2 aa batteries and the wall drops into the groove
Post by lostpict » Mon Nov 13, 2017 10:52 pm
Sweet - this stuff is better and better.
simage4344
Post by simage4344 » Mon Nov 13, 2017 8:58 pm
Still working on the fit of the small window frames. The dimensions vary from window to window it seems.
simage4344
Post by simage4344 » Mon Nov 13, 2017 6:58 pm
Post by Oldent » Mon Nov 13, 2017 5:27 pm
I do not have any city builder tiles. I most likely will throw the window adapter into the parts ben and drill a hole.
One of the upcoming Green Hoard tiles is a mill tile. The mill interior has the mill stone. I also want another wheel for a Hobbit mill I am working on.
The mill tile. I will probably want a broken wheel too. I think the whole wheel will most likely look better.
Post by lostpict » Mon Nov 13, 2017 4:28 pm
I really like the combo wheel and works.
simage4344
Post by simage4344 » Mon Nov 13, 2017 3:59 pm
Post by Oldent » Mon Nov 13, 2017 3:28 pm
simage4344 wrote:
Mon Nov 13, 2017 1:47 pm
Ok. I will borrow some water pieces from my friend and set up the scale of the wheel to attach to a window wall piece sitting on the small floor spacer piece on a double high house wall (if that makes sense) and just be high enough to clear the water tile. I will look into motorizing it (because that would be cool) and not do any special internal pieces. Will be a week or so before I get the updated wheel done. (And will look into creating a windmill attachment).
In the mean time, I will add in the "downward steps into darkness" floor inserts for wood and stone floors after I print them up tonight. Also hope to have some window options for the tower and abbey windows printed.
"not do any special internal pieces"
Why?
I do not want roofs! That is not a reason not to make them.I do not want to motorize that is also no reason not to :!:
Users browsing this forum: No registered users and 8 guests
