Citadel Woods Painting Project
Re: Citadel Woods Painting Project
Post by William » Fri Dec 21, 2018 6:46 pm
I really should double check things before posting... "romoved" = idiot word for removed. Oh well. :oops:
Post by William » Fri Dec 21, 2018 6:38 pm
Thanks. :D
I have not forgot this, just not ready to do the tutorial yet. Here is a teaser for Christmas. ;)
Flame Bend 001.jpg (91.81 KiB) Viewed 2565 times
Flame Bend 002.jpg (102.88 KiB) Viewed 2565 times
Flame Bend 003.jpg (82.61 KiB) Viewed 2565 times
So, sometime 'soon' after the holidays I'll try to get it finished... ;)
Feymous
Post by Feymous » Sun Nov 25, 2018 12:44 pm
Those look great William!! I particularly like the nest tree. Perfect place for a woodland encounter :D
Post by William » Wed Nov 21, 2018 5:14 pm
Weird, never could get picture to come up in Photobucket.
Isn't it a day early for all the family food fight photos being loaded? :lol:
Post by Oldent » Wed Nov 21, 2018 3:09 pm
I used a sponge to paint the base because some of you don't like flock. I will flock later.
Post by Oldent » Wed Nov 21, 2018 9:38 am
I used lava red to cover the green.
I think that the school bush yellow will highlight the the green as well as it does the red.
Photobucket is slow so no photo ;)
I did not use my GW leaves.
The plastic leaves might make good ivy. I will see if I can find them this afternoon and see how well boiling water works.
I always look forward to Williams post.
Post by William » Wed Nov 21, 2018 2:44 am
Here is a picture of the two weir trees from CMoN's A Song of Ice and Fire KS.
One, I had done quite a while ago, now I'm matching the other one and six smaller trees from same KS.
The darker color you see is two base coats of Pokorny, Shallow Water Seaweed Green and then an ample dry brush of Pokorny, Moss Green on the other tree. It's that simple and paint "we" all should have. The second coat was needed to cover the red plastic leaf clusters better. I also did two coats on the smaller trees, because the light green plastic leaves with only one coat, made it have a different base tone. So two base-coats on each of the different colored trees. I think I did some small green ink (Army Painter) splotches originally in the deeper areas. I'll have to see how these go when I do the dry brush. :?:
Anyway, here are the two trees mentioned. I'll post more pictures of the trunks and small trees when done. ;)
CMoN ASoIaF Trees 0010.jpg (106.32 KiB) Viewed 2556 times
Post by William » Wed Nov 21, 2018 12:56 am
I had an idea right before I was done painting the leaf clusters on the sprues, but that was too late to try it out.
I like the look of the GW Citadel Wood leaves, but wish there were a little curve to them. Maybe not as much as the CMoN ones shown above, but similar.
The plastic is fairly hard and would break without softening first. I tried some very hot tap water on some of the branches and it didn't do anything. I could have tried boiling water but only wanted a quick bend or two, so I use flame... candle, it worked but be short-n-quick. The plastic will blacken a tiny bit too.
Anyway, my thought was to boil water put a leaf cluster in before painting and use two spoons (in the water, while boiling) to create a slight bowl shape. The drawback is painting a bunch of leaf clusters individually. I found doing it on the rack of them, much easier. So, maybe disconnect all but two connections and try the spoon thing on the sprue?
That was my idea to "un-flatten" the leaves for these, but was too late to try. ;)
I also wish some of them had a bit more depth. So I layered a few (wish there were a lot more clusters per tree) on one another to try and break up some of the reoccurring leaf clusters and give some depth.
GW CW Leaf Layers 001.jpg (93.2 KiB) Viewed 2560 times
GW CW Leaf Layers 002.jpg (95.11 KiB) Viewed 2560 times
GW CW Leaf Layers 003.jpg (90.63 KiB) Viewed 2560 times
Wish I had the patience to do another set in fall colors, maybe in the next decade. ;)
Post by kodiakbear » Wed Nov 21, 2018 12:10 am
Watch Out! Dave the Gnome your about to be attacked.
Post by William » Wed Nov 21, 2018 12:03 am
Nope, those are the trees from CMoN's, A Song of Ice and Fire KS. They said exclusive, but CMoN should just sell them in web store. The set of 3 are going for $50.00+ on eBay. The Larger Weir tree is the same. I got two of each set in KS and wish I had one set more of each.
Users browsing this forum: No registered users and 16 guests
