Re: Fix warped parts? How to create a wash
Post by Oldent » Thu Jun 28, 2018 8:55 am
I may use a terracotta drybrush on the brown bricks. The metal needs a highlight.
I am going to work on the mine doors a bit before I highlight with Brook Green.
The back side still WIP
Plug for Undead dragon. I also use thin lava as a base coat for a miniature will have to see if I can make it work.
I used the Army Builder bone as a primer for the Dragon.
Post by Rabbit Burner » Thu Jun 28, 2018 4:16 am
Admit it this is just a shameless plug for the Zombie unicorn!
Great pictures and info as usual Oldent :)
See DooFers even unicorns don't get a free pass if they cross Old Man willow and venture too far into his multi dimensional lab of the weird, wonderful and downright dangerous. Definitely spotted some arterial spray!
Post by Oldent » Wed Jun 27, 2018 7:52 pm
Thanks, Kryzsko
Post by Kryzsko » Wed Jun 27, 2018 3:21 pm
Fri Jun 22, 2018 5:05 pm
The Double door did not need hot water.
I spent some time working out how to paint Table Scapes to match my Dwarven Forge.
The Table Scapes is very close to DF base gray in color. I base coated it with Umbar mixed with Black and dry brushed it to match
picked out some details with umbar and card board
Dry brushed with Glidden Diamond Glazed Ginger
Dry brushed wit Glidden Diamond Brook Green
Now to finish up the Rabbit :D
Both the speed and the quality at which you get stuff painted is amazing.
Post by Oldent » Wed Jun 27, 2018 2:41 pm
added stone edge and cavern dry brush.
Post by Oldent » Wed Jun 27, 2018 10:45 am
This is still very much a WIP photo
I decided to try to use the Dark Lava as a wash. The pillars look better than the doors.
To create a wash add a few drops of acrylic binder like floor wax. I f you want the wash to be flat, Woodland Scenic scenic cement works well.
The Woodland Scenic Pigments do not have a binder. They are designed to be applied and set with the scenic cement.
Post by Oldent » Mon Jun 25, 2018 11:13 am
Floor WIP
Post by Oldent » Fri Jun 22, 2018 6:26 pm
Fri Jun 22, 2018 6:21 pm
Oh, yes. Nice job on them, OMW.
From Zombicide 'Horde Box' in the Green Horde KS.
You sure got those painted quickly.
I'm still just sorting through those still.
My Cyclops is somehow throwing a large chunk of Basalt Column :?: and also now has two eyes :?: ... it's wierd. :?:
I need to still paint him, then post a few shots. ;)
Can not wait to see it!
Post by William » Fri Jun 22, 2018 6:21 pm
Post by Oldent » Fri Jun 22, 2018 6:20 pm
Vegomatic wrote:
Fri Jun 22, 2018 6:04 pm
A zombie unicorn?!?!?
From Green Hoard Zombicide.I will finish it up along with the Rabbit
I hate painting eyes :cry:
