Regluing magnets to magnetic pieces
Re: Regluing magnets to magnetic pieces
Post by GODofwar » Thu Apr 21, 2016 3:22 pm
Dice:
Neh, I have three Large Tubs and a bunch of small ones left in the terrain wall of my KZ...which should just about be filled up by KS4...
I am trying to sell 3 large cupboards worth of games. THen I would have room for KS5....
meh..
Totus KS Delendum Est - especially this one
Post by dice4hire » Thu Apr 21, 2016 2:54 am
Tyrant1969 wrote:Thanks guys!
What else have we got for KS5? :)
Well, I think most of us will be inteh market for a new hosue to store everything in in early 2017
Post by AnimeSensei » Thu Apr 21, 2016 1:41 am
Lots and lots of debt? ;)
Tyrant1969
Post by Tyrant1969 » Wed Apr 20, 2016 8:31 pm
Thanks guys!
Post by AnimeSensei » Wed Apr 20, 2016 7:43 pm
Tyrant1969 wrote:This question is a little off topic, but what kind of glue is best for the older resin pieces?
I've used superglue and my pieces have not broke since I glued them.
Post by Vegomatic » Tue Apr 19, 2016 9:18 pm
Suzy recommended jb weld to me.
Tyrant1969
Post by Tyrant1969 » Tue Apr 19, 2016 7:46 pm
Post by GODofwar » Sat Feb 27, 2016 10:39 pm
biowizard wrote:For epoxy, I like the "slow cure" version such as this one: http://www.hobbyking.com/hobbyking/stor ... _5_oz.html
The fact that both bottles are kept separate and have their own cap makes it that I've had the same bottles for many years (with regular use) without it "drying" on me. A "must" in my opinion for a hobbyist.
COncur. Although I generally use the fast-cure two part epoxy for specific reasons.
Post by dice4hire » Fri Feb 26, 2016 2:04 am
Im sure getting all the post holes the exact right size in dwarvenite is not easy.
Post by jchunick » Thu Feb 25, 2016 11:37 pm
lostpict wrote:Is this what is also recommended for loose pins in the posts?
You can actually use cyanoacrylate (aka crazy glue) or gorilla glue, I guess, for the pins. You need very little - partially because the pins are such a tight fit that you don't need the mess of a whole bunch oozing out when you re-insert the pin. I've used a gel cyanoacrylate that works rather well. there's much more surface area between the pin and the hole wall so the glue works well. As well, the force of friction is close to the same on the pin coming out of the hole of the floor as it is coming out of the post so adding some glue easily overcomes that.
There's a bulgy bit with teeth on the end of the pin that goes into the post hole that's supposed to overcome the friction on the pin when being pulled from the floor hole. But I guess the tolerances on the holes are not exact enough and some post holes can be a bit larger, thus the pin comes out of the post hole.
Return to “Kickstarter Updates”
