Alternate uses for LED torch stands
Re: Alternate uses for LED torch stands
Post by GODofwar » Mon Jan 25, 2016 10:29 pm
William wrote:I said "something like" and it did have a skull, marble, urn, and two flame sizes per light fixture. If you missed them, go find your boxes, you have some little bags to go through. ;)
<<panic as Weasel races downstairs hoping he still has Cat @ separated...and little bags have not been eaten by the cats>>>
Totus KS Delendum Est
Post by William » Mon Jan 25, 2016 10:24 pm
EDIT : This a the mix from two #2 sets and two 6" LED walls -
Post by GODofwar » Mon Jan 25, 2016 10:20 pm
William wrote:Neat idea. :idea: You could supply different colored opaque or clear rings to interchange at your whim. Something like all the different flames and pieces supplied with the Cat #2 sets.
Did I miss something in the Catacombs 2 sets?/ DIfferent colored flames nd pieces? Do I need to run to the KZ and look?
Post by lostpict » Mon Jan 25, 2016 8:48 pm
I play LOTR a lot and any color would do, mostly just a reminder that a model causes terror. I would guess that white, yellow, green, red, orange, violet, blue, and purple would be good targets.
Post by jchunick » Mon Jan 25, 2016 7:46 pm
pacarat wrote:
lostpict wrote:A small bit threadomancy, I would like glowing bases to indicate active spell effects. Any idea how to do that with LEDs?
maybe removable hollow transluscent plastic rings or arcs sandwiched in/under the base? then you only need a single clear led light., and customize the effect by using the appropriate color(s).
picture an oreo cookie, with led, etc., as the filling, and plastic arcs stuck in around edge, between the wafer parts. :)
Yeah, I like that idea a lot. So, anyone want to pipe up with what colours should reperesent what?... or just what colours could be used?... assume between 4-6 colours.
Post by William » Mon Jan 25, 2016 7:03 pm
Post by pacarat » Mon Jan 25, 2016 6:55 pm
Post by William » Mon Jan 25, 2016 4:06 pm
Sorry, Rune asked. :oops:
Aren't you busy looking for a "pict" anyway? ;)
Post by lostpict » Mon Jan 25, 2016 2:11 pm
Josh,
Thanks. I used to work in the LED business (Cree) and the actually LED chip was tiny, but all rest of it (lens, battery, wires, package, circuit must be 300 times bigger).
Forar80
Post by Forar80 » Mon Jan 25, 2016 1:54 pm
I haven't received my package for KS3 yet, but have been looking forward to using a stand with the game Shadows of Brimstone, which has a 'lantern bearer' (a thankless job that gets blamed for a lot of problems). Having the LB actually have a lit base seems like it'd be just amazing, and I've used DF dungeon and cavern tiles in the past to augment the board game pieces when I'm feeling particularly adventurous.
