Alternate uses for LED torch stands
Re: Alternate uses for LED torch stands
Post by jchunick » Mon Jan 25, 2016 1:24 pm
lostpict wrote:A small bit threadomancy, I would like glowing bases to indicate active spell effects. Any idea how to do that with LEDs?
The easiest way would be with a BlinkM MinM LED chip. You can find them here:
http://thingm.com/products/blinkm-minm/
However, they're comparatively bulky and you'd also still need a way to switch between colours.
Post by lostpict » Mon Jan 25, 2016 9:31 am
Post by William » Sun Jan 24, 2016 11:56 pm
That's the one, in Tukwilla east of Boeing field.
The wife still works there, on her 29th year.
A meet sounds good, next time you are heading this way give a hollar - PM or post here.
Hopefully I'll get my game room cleaned up by then. Ha, it's been a wreck for years. ;)
Bill
Baitsauce - Give it time you'll get there, then you'll wish for widgets on stressful days. For me 3D CAD turned out to be the best tool for drawing custom spider hangers for multi angled beams. We did a few roofs in Russia with arched beams and rounded cielings. They were a nice challenge to draw. One of those houses was 25,000 Sq. Ft. and took a year and a half to draw. That sucker stretched our computer system to the limit when running elevations and cross sections. It would take hours of rendering per drawing. Enough reminescing. :(
Post by GODofwar » Sun Jan 24, 2016 10:48 pm
William:
Driven by Lindal hundreds of times - mostly on I5!
Hey, we get home usually at least once a year. I"d enjoy getting together if you're interested.
Totus KS Delendum Est
Larry
Post by GODofwar » Sun Jan 24, 2016 10:47 pm
William wrote:A short history of me - :oops:
From structural and street engineering to comercial buildings to custom home design down to the blue print guy (I guess I moved up from there, not down to there). Most of my career was designing and drafting custom home plans. I started drawing very early and blew off college to work, school was always very dull and extreemly easy. Except english classes were always gibberish to me, hated them. So I learned early my mind works in pictures and numbers, but not words or punctuation. After years working in Fresno, CA at a half dozen places I screwed up personally (whole other story) and had to start over up north where my brother moved to years earlier. Once I found them I settled into an 18+ year career with Lindal Cedar Homes based out of Seattle, although they sell thier homes worldwide. Blew my back up, had 3 operations, titanium installed, no real help. :x :( :cry: TMI?
I've always had the ability to see things in 3D :ugeek: , which was a plus in the old days of hand drafting. But with the advent of Computer Aided Drafting, any trained drafter can spit out designs in 3D so clients can visualize the design. I wish I had more schooling in hand sketching with color and spelling (haha, not really - I don't care anymore), but I can usually convey an idea quickly with my Post-It-Designs.
3"x3" is a big drawing for me these days.
I think it's been over 7 years since I opened a drafting program. I probably wouldn't even remember how to format a drawing. "Use It or Lose It" is so true. My priorities have also changed over those years, so no biggie.
William, in reply - my shorter history: The only class I every flunked (D) was drafting. My junior high teacher refused to believe that when I looked at a properly done 3D perspective all I saw was lines on a paper. Solly, Colly, that's all I saw.
Things have gotten better but not much. I build, not draw!
Post by Runeweaver » Sun Jan 24, 2016 10:43 pm
I had done the torch bases some time ago. Mine was magnetized, as I had put rubber ferric bases on the bottoms of my player characters figs. That way it stuck to the mini as they moved it around. It worked ok. I made several of them, but it does add some height to the mini. Josh's are more refined then mine though.
photo 2 (5) (765x1024).jpg (351.22 KiB) Viewed 2723 times
IMG_0916 (478x640).jpg (108.83 KiB) Viewed 2719 times
Post by Runeweaver » Sun Jan 24, 2016 10:36 pm
Thanks for the backstory, William. I could certainly see from your "quick sketches" (which would have taken me far to long to make, even if I could make them) that it was a job acquired and refined skill. True you may have always had it, but repetition and need honed it considerable I would gather.
Always a joy to see your sketches.
BaitSauce
Post by BaitSauce » Sun Jan 24, 2016 10:05 pm
Drafter here as well, but only been doing it for 5 year so far. Spacial awareness even with C.A.D. programs is probably the most valuable skill. I don't get to draw plans too much, I mostly generate piping isometric drawings for a fabrication shop. Trying to start getting into floor planning though.
Post by AnimeSensei » Sun Jan 24, 2016 12:11 am
Sounds like your next market niche is designing tabletop gamers' houses or game rooms. :)
Post by William » Sun Jan 24, 2016 12:01 am
