Alternate uses for LED torch stands
Re: Alternate uses for LED torch stands
Post by jchunick » Sat Jan 23, 2016 12:21 pm
jchunick wrote:
Oldent wrote:Could you not add a table cloth and plates or books and make tables or desk? :?:
Sounds like an interesting idea... I've seen pics you've posted before with tablecloths so give it a try and post your pics here.
I had to choose between a little of everything and enough to do something so I dropped the free stuff for sewers and streets.I won't have any.
Felt Paper and .17 cal airgun pellets.
Well, I can give it a go, sometime. The torches standing as high as they are may look a bit odd, though. It'll need legs to sit on, as well... hmmmm, I don't know how well that will work.
Post by Oldent » Sat Jan 23, 2016 10:15 am
Post by William » Sat Jan 23, 2016 4:20 am
I had this same idea back when they brought them up. Big band maybe not, but a quartet should fit maybe up to six vocalists. I was thinking four part harmony... :o :o :o :o
Another thought is to set four of them over a few stacked floor tiles with short stairs up to the rear of one or both sides of the stage.
I also had the thought to maybe find or sculpt some light shields for four of the lights. :idea:
I only will get the 5 with the Capitol City pledge, but I think they will be used quite a bit.
I'll take a pick whenever they get here, unless someone with painted versions will do it first.
Post by jchunick » Sat Jan 23, 2016 1:41 am
Post by Oldent » Fri Jan 22, 2016 11:35 pm
Post by LordDust » Fri Jan 22, 2016 8:02 pm
Not a bad idea. I was thinking two together could make a small indoor or outdoor stage. Four could make some sort of center piece for a big bad or an important speaker.
Post by jchunick » Fri Jan 22, 2016 7:51 pm
Here's an alternate lighting use for the LED torch stands, especially if you didn't pick up the LED walls, it's free lighting (since it was a stretch goal).
