Storing your Dwarven Forge
Drammattex
Re: Storing your Dwarven Forge
Post by Drammattex » Sat Jan 30, 2016 6:22 pm
THANK YOU!!!
Post by Vegomatic » Sat Jan 30, 2016 5:28 pm
Drammattex wrote:
Vegomatic wrote:Here are some photos of a sample of my current CBS storage...
I really like these. Where do you get them?
The larger tubs are Iris Storage. They measure approximately 11x16 and about 6 inches deep. I bought a multi-pack of them from Costco a few months ago. I don't see them on their website but it may be seasonal.
The smaller organizer is a Plano Stowaway. It is a very old model... one I had on hand from years ago (14x9x2.5 inches). You will probably want a newer model anyway (Plano Stowaway Pro-Lock)... as the latches on the old ones break after some use. Walmart and other stores carry them... Here is a link to the Plano site: http://www.planostoragesolutions.com/ca ... waway.aspx
And on Walmart here one a little smaller than my old one:
http://www.walmart.com/ip/Plano-Molding ... s/35848208
Storing your DwF - Cheap Method
Post by GODofwar » Sat Jan 30, 2016 4:56 pm
I just use the boxes they came in - inside large storage tubs. Easy to label - I circle the image on the front showing whats inside, then put a label in each corner of the box top:
TYPE (ruins, wall, floor etc) STYLE (stone or Tudor)
SPECIAL (with window, with door etc) QTY (how many)
I only put one Style and Special category in a single box. I use thick black marker on top, and duplicate the label on one side so it can be seen through clear tub walls.
Then I stack stuff in the same order in each tub. Stone walls along one side, walls with windows in the middle, etc. If appropriate I stack items with lots of and the right shape on the bottom of the tub (like sewer walls) and leave them loose. I make sure the bottom is full so they don't rattle around - sometimes this means a box in sideways, even an empty box.
When building, I usually only need one tub at a time - ie, I will build all my Tudor buildings at once, all my stone buildings, all the sewers etc. If I know I have half-and-halfs, like a stone first floor with Tudor second floor, I will try to build those by dumping what I need before storing the Stone tub , then finish as soon as the Tudor tub comes out.
This is analogous to how I use my storage drawers for resin.
Cheaper than buying the plastic tubs, but I really do like the plastic tubs from Target mentioned above (many stores carry them).
Totus KS Delendum Est
Drammattex
Post by Drammattex » Sat Jan 30, 2016 3:50 pm
Post by kitenerd » Wed Jan 27, 2016 4:49 pm
my spreadsheet fell apart sometime after the D&D minis game ended... i no longer needed quite as firm a grip on what i had, plus for a while there the minis were CHEAP and i was buying tons... those days are gone ;)
Magniopi
Post by Magniopi » Wed Jan 27, 2016 3:37 pm
kitenerd wrote:I have a ridiculous amount of prepainted plastic - i have lost count. Yes sorting them is a problem. When i run something, i typically throw them in a box when it is over. Ever few months i spread all the containers on the floor, dump the unsorted box and put on a good movie. It takes forever to put them all in their proper places ;)
Heh, I do the EXACT same thing, right down to sitting on the floor in a semi-circle of open containers. :D
I'm a little embarrassed to admit I keep spreadsheets of my D&D and Pathfinder minis. At this moment, I'm at 2492 of those, plus another hundred or so (unspreadsheeted) Dwarven Forge, Dungeon Crawler, Safari Dragons and Toob Horses, Schleich Dragons, etc.
Audles
Post by Audles » Wed Jan 27, 2016 3:23 pm
I use those same boxes for my minis. Best kept gamer secret at my local Fred Meyer store.
Post by kitenerd » Wed Jan 27, 2016 2:59 pm
Magniopi
Post by Magniopi » Wed Jan 27, 2016 10:00 am
A few of my Sterlite tubs with prepainted miniatures.
Sterlite Mini Storage.jpg (91.08 KiB) Viewed 5785 times
I'd like to have the minis better sorted within the tubs, but as time has gone on the number of them has made neater systems like kitenerd posted problematic.
As it is, they're just sorted into various sizes of plastic baggies within the tubs.
Post by kitenerd » Wed Jan 27, 2016 3:12 am
I use these for prepainted minis:
http://www.amazon.com/Darice-17-Compart ... rds=darice
you can get them at beverlies or michaels for under 2 bucks - they are designed for embroidery floss
the photo is terrible, but there are 16 small slots and 1 double length slot - for medium minis depending on sculpt you can stick 2-8 per slot - i have probably 20 of these (undead, orcs, drow, dwarves, mages, clerics, kobolds etc.) makes it really easy to find your minis
here is my box with DF minis:
as you can tell, this could easily hold 5-6 sets of lizardmen
when i prepare to run an adventure, i pull the minis and just put them in slots by encounter - then i can just go to the next slot or two every time the PC's hit another room
Sadly once you get to large and above, all of my minis are just tumbled into bigger tubs that i must stir through...
