Lava Caverns painting scheme
Re: Lava Caverns painting scheme
Post by pacarat » Sun Nov 05, 2017 9:10 am
Mottled open lava has a really nice effect.
Post by dice4hire » Sun Nov 05, 2017 3:25 am
Very nice technique.
falerion
Post by falerion » Sun Nov 05, 2017 2:52 am
Here an update for the Lava River tiles with step-by-step walk-through (also using only DF colors):
1) A wet-brushing of the whole tile with Lava Yellow. You might need several layers as the yellow paint is a bit thin.
2) A wet-brushing with Deep Lava on the rim between the flat area and the raised part of the tiles. I intended to have a darker orange near the rim.
3) A heavy dry brush with Lava Orange on the cavern part of the tiles.
4) With a sponge the (Deep Lava) rim, part of the yellow flat area and the cavern parts, are dabbed with Lava Orange. Dab the sponge into the paint and then dab on a paper towels until you get a feel for the pushing force and the amount of paint you need to get a pattern you like. The sponge should be turned around during dabbing to avoid a pattern on the tile.
5) With a brush apply a light Black dry-brushing on the cavern part of the tile.
6) With a sponge and Black paint dry-dab the rim and a part of the flat area. Dab the sponge on paper towels before hitting the tile. Again avoid patterns with the sponge.
7) Apply another layer of Lava Orange with the sponge all over the flat yellow area. You might not want to do this step if you want bright yellow lava in the river instead of the orange look.
And here a picture of the sponge I used next to a tile. It is kind of coarse.
Post by Rabbit Burner » Thu Sep 14, 2017 4:49 am
Very Nicely done :D
Great step by step too - always amazed how you get from step 1 to the finished article as they look soo different.
A little too hot for us bunnies and the stink!
pooo-eeeeee
Post by bernyleung » Sun Sep 10, 2017 11:55 pm
Great job! Maybe I'll do one of my KS5 rooms in a similar scheme.... (no, I'm not getting the Lava Bridge)
Post by dice4hire » Sun Sep 10, 2017 11:28 pm
Very well done. I did some freestanding walls in a similar way(with fewer steps) and I did some stone edge on the tops of the walls to give a bit of an ash look and to tone down the gloss a bit. Pokorny Black is really glossy.
Post by dice4hire » Sun Sep 10, 2017 10:49 pm
Post by Harneloot » Sun Sep 10, 2017 9:31 pm
Fantastic! Would love to have a wider range of tiles for my lava sets like you have created - as they are, the lava sets are a bit repetitive in a build.
Post by Vegomatic » Sun Sep 10, 2017 8:25 pm
Those are incredible!!!!
Love the step by step and use of Dwarven Forge colors. Thank you so much for sharing!
Very well done!
Post by GardenDM » Sun Sep 10, 2017 5:49 pm
Awesome paint job and thank you for the write-up!
