Ice Caverns Paint Job
Re: Ice Caverns Paint Job
Post by jchunick » Thu Dec 15, 2016 1:27 am
kiltedyaksman wrote:I'd like to talk to the OP but I'm not sure the messaging system is working properly for me...
I know I'm not the OP, but maybe we can help you out if you have any questions about painting the ice caverns. :-)
Post by Kryzsko » Wed Dec 14, 2016 6:45 pm
I love all these different ice paint schemes.
kiltedyaksman
Post by kiltedyaksman » Wed Feb 18, 2015 1:46 pm
Re:Ice Caverns Paint Job
Post by kitenerd » Mon Jan 12, 2015 3:23 am
WOW - that is really awesome...
Unlit it looks good -Lit it looks fantastic! I cannot believe how cool the piles of snow on top look - such a great effect!
BRAVO!
Post by jchunick » Sun Jan 11, 2015 8:48 pm
I just finished this test to see if adding some fine glitter for a nice shimmering effect would work. I also wanted to test with this piece because the hole makes it easy to try out a blue LED inside.
To go through the details, I used some Dollar Store (from Canada) DecoArt Crafter's Acrylic 'Light Antique White' and 'White'. I also used verdigris glaze and blue ink. I applied the antique white first as a bry brush, much as you do if you paint the stone highlight on the dungeon tiles. I was a bit heavy on all the top edges of the various "levels" on the mound. Then I added the mix of verdigris glaze and ink, decently watered, and washed that all around and into the crevices. I had to dab off spotty areas with a wet brush as the ink mix dried... as well, I would often brush upward to get it a bit more evenly applied. Lastly, I used the 'White', drybrushing on the most bumpy surfaces. Lastly, I applied thick white onto the tops of the ridges where I figured snow build-up would be heaviest. I did this part quick since I was going to apply the Extra Fine Glitter (made by ArtMinds and bought at Michaels with 50% off coupon) to the heavily applied white paint. I made sure to have it on a paper plate so I could catch the excess glitter to put back into the container later.
Here's how it turned out:
Mariolls
Post by Mariolls » Wed Jan 07, 2015 4:00 pm
natetaylor
Post by natetaylor » Tue Dec 02, 2014 7:54 pm
Gorgeous work.
The Realistic Water in the crevices is fantastic.
These are perfect.
fnordfriendly
Post by fnordfriendly » Tue Dec 02, 2014 7:38 pm
I just finished painting 3 sets. I mixed 48 drops of Pokorny white with 3 drops of water bubbles to get a toothpaste color. I used this base to paint the bottoms of all tiles, then I lightly dry brushed all pieces with the same color. I then dry rushed lightly with white, then painted the top edges of all pieces white. I painted a heavier coat on the hanging drippy bits.
I wanted a dramatic look, with heavy whites and subtle blue undertones. The translucence is preserved, though it's not apparent on the pic. I want to use scenic water effects in the recesses, that was a good idea. Just need to pick some up from the local hobby store.
brvheart
Post by brvheart » Tue Dec 02, 2014 7:06 pm
These look really nice, but I am not sure I can improve over the clear with my level of painting. We will see when I get the rest painted.
Undel
Post by Undel » Tue Dec 02, 2014 5:32 pm
You are making me regret not picking up the clear tiles. Those look fantastic! Thanks for sharing!
