GREEN STUFF Mods to Dwarvenite
Re: GREEN STUFF Mods to Dwarvenite
Post by William » Mon Aug 03, 2015 5:22 am
EDIT: This is the second of two posts, other one is at end of last page (Page #3).
Two small floor mods, Mostly cutting, but there is one small green stuff dot added to one of the floor pieces for stability. The part you don't see in these pics is the edge of the underside filled to create a lip. These were mods to one standard floor tile (gray box) and then 3 modifications to each of the 2 larger corner chasm floor pieces. The two chasm floor pieces were easier and left a bit less waste when done. I cut one each of the pieces from a standard floor tile and the other 6 are from chasm pieces. They're not the best fit, but then again it is a cavern floor.
Mod to Floor Tile and Chasm pieces for back of CornerA and CornerC -
Now some new holes and one mod to critter hole.
Two small holes and one large hole -
Two new hole pieces -
A larger hole -
All three -
I'll try to get to the creek and puddles soon, here's another tease.
Later... ;)
EDIT: Yes, those are my initials. Was laying out for a picture and noticed with a few shifts I could get close. I'll post some of the wall and corner creek pieces in a few days.
Also, I appologise for the text not lining up with pictures, I think I fixed that. ;)
Also want to bump last post on end of last page, it got lost in the shuffle.
viewtopic.php?p=90246#p90246
Thanks and post your own mods.
Post by William » Mon Aug 03, 2015 4:58 am
Here are a few more mods.
CornerA mods -
These are the jagged pieces left over from mods shown to chasm pieces on next post/page.
I'll be using these when stacking levels to have an undercut in a cliff wall. I might do a few walls like this and one with a short passageway through wall.
CornerB Mods - Just filling in back to use at another wall junction.
and another CornerB mod- This one is a WIP with a pool on back of wall.
Added a few stalactites to wall to cover seam.
A quickie set-up with a few of the new pieces. Has all four of pieces in this post.
I still need to fix a few things on these and smooth out bowl on last CornerB mod.
I'll put the next two pieces in the next post. Too many pics in one post... :shock:
Audles
Post by Audles » Thu Jul 30, 2015 2:17 pm
That's a damn cool ta-dah. Too bad I don't even possess a modicum of the self-confidence it would take to cut up pieces like that!
Post by William » Thu Jul 30, 2015 4:46 am
Thought I would toss a link to my Dwarvenite Cutting Thread since I'm showing lots of cutting in these mods. So...
viewtopic.php?p=79142#p79142
Have fun with this stuff, it's all for kicks anyway. :P
Post by Oldent » Fri Jul 24, 2015 8:50 am
I am looking forward to your next post. They are always very creative.
Post by William » Fri Jul 24, 2015 2:09 am
Thanks Oldent, unless that was for Josh, then I'll just tag along...hehe
I thought I would add these two mods, even though they don't have any Green Stuff. I did cut them, which is also a step in the proccess, so I'm only partially cheating the thread. ;)
Critter run pieces. I did a small change to fit them in between two 2" tiles in a layout. the little slopped piece is about an 1/8" off to slap two together to fit in one tile width. I did notice the slivers are tapered to created a more 90 degree angle off the wall. Anyway, I didn't cut the critter bed, just the sloped pieces, but did each one (of two) from either end. You'll see. (Yes, I scuffed the end up of bed, but didn't remove any depth.)-(Yet? ;) )
Here is the 45 degree cavern passage angle cut into two 22.5 degree angles. This way I can match up any combo of pieces. You can also introduce more of a zig-zag to reduce sight lines for spells and arrows... :twisted:
p01 DSCN2470.jpg (235.53 KiB) Viewed 7558 times
Now for a bit of fun ... :oops:
Ta-Dah...
More walls soon, then corners and specialty items along with the puddles and creeks.
Post by Oldent » Thu Jul 23, 2015 7:02 pm
I always enjoy your post
Post by jchunick » Wed Jul 22, 2015 6:49 pm
William wrote:I've even dropped small mixed pieces into water while I work on a different area. Just knead the putty a little after you pull it out to work out that "saturated" feel. It should come back to the texture before you dropped it in. I have noticed the water I have left it in will get a wee filmy, so something is comeing out of the putty into the water, but it's not like were trying to stop a leaking pipe. Note, GS will eventually harden in water, but it will also keep it from setting up longer than normal and it keeps it from sticking to whatever you set the chunk on.
I have not used PJ, but does it screw with painting later?
I've only used my greens to create molds so I'm not sure about the 'painting later' part... but I'd imagine it just needs to be washed in hot water with some soap and then rinsed good and it'd be fine.
Post by William » Wed Jul 22, 2015 2:57 pm
kmj9907
Post by kmj9907 » Wed Jul 22, 2015 1:43 pm
jchunick wrote: Yes, I've used petroleum jelly and it works well. I haven't noticed any side effects.
Great Thanks!
