CBS - Tips, Tricks and Modifications
Re: CBS - Tips, Tricks and Modifications
Post by jchunick » Thu Sep 08, 2016 2:08 pm
Here's a pic that shows the initial cuts a bit better:
2016-09-08 14.06.15.jpg (390.64 KiB) Viewed 4388 times
2016-09-08 14.06.35.jpg (382.74 KiB) Viewed 4388 times
ForestZ
Post by ForestZ » Thu Sep 08, 2016 12:08 pm
jchunick wrote:William, you're going to like this mod, guaranteed! :D
It's still WIP, but you can see the idea. The balcony now sits flush. There's a chunk of space that needs to be filled in with some sculpting. Once I get the posts properly aligned I will then glue the pegs in. They nor only keep the separate pieces together and aligned, but provide support and a framework to sculpt around.
:shock: Love it.
Post by jchunick » Wed Sep 07, 2016 10:17 pm
2016-09-07 22.11.03.jpg (402.23 KiB) Viewed 4335 times
Post by William » Fri Aug 26, 2016 3:55 am
Thanks Stefan. :)
Tip #7 (I'm counting Josh's Diagonal Windows as #6) - Bar as Counter -
You can fit the Long Bar between the posts (short or tall) as a counter wall.
Fits nicely between the V-grooves to fill wall opening.
Tip #8 - Window wall sorting when storing.
I mentioned this before in another thread, but thought it would fit here as well.
Just store window walls upside down with window painted in a light color down that channel. Match the size of paint line and location with window(s) or arrow slots above. I did Bubble Blue for windows and Lava Orange for Arrow Slits.
Window Wall Designations.jpg (159.38 KiB) Viewed 4413 times
And? ;)
Spiropolous the Minotaur
Post by Spiropolous the Minotaur » Wed Aug 24, 2016 8:35 pm
Great, great stuff!
Post by jchunick » Tue Aug 23, 2016 12:18 am
William wrote:I like that too. The first time I looked at these two pictures they were both the same product picture and I wasn't sure where you were going with it. Glad to now see the diamond pattern in the window.
Looks great. Thanks 8-)
It took me less than 5 mins. to fix it :-P and I figured nobody had seen it in that time... but yeah, it was a weird thing because I originally uploaded the image of the house and window first, yet it disappeared on me and I ended up posting the 2nd image accidentally in it's place.
Post by William » Mon Aug 22, 2016 11:23 pm
Post by jchunick » Mon Aug 22, 2016 11:03 pm
Runeweaver wrote:Man, I like that josh. If I find some, consider it copied. I'm still working on Stained glass, and I think I have an idea.
Thanks. Glad you like :-)
I'm very interested in stain glass, so please share here when you get it figured out.
I'm probably going to try William's shutter and curtain trim. I like to put the curtain and shutters together in a window, but it can be tricky and they kind of stick out from the wall quite a bit. A trim should fix that.
Post by Runeweaver » Mon Aug 22, 2016 10:52 pm
Post by jchunick » Mon Aug 22, 2016 8:14 pm
If you're not into "destructive" mods then here's a "non-destructive" mod you can do to your CBS shutter to add a bit more Tudor-ness to it :-)
2016-08-22 20.03.46.jpg (402.33 KiB) Viewed 3888 times
I bought a product called Darice Plastic Canvas, in black. I also cut a piece of clear plastic for the window glass from some kids toy packaging.
2016-08-22 20.14.20.jpg (362.58 KiB) Viewed 3891 times
