CBS - Tips, Tricks and Modifications
Re: CBS - Tips, Tricks and Modifications
Post by kodiakbear » Fri Aug 12, 2016 8:17 pm
If many of Williams best mods do not become pieces as part of KS5, I suggest he starts a store right after the KS ends.
I know I would happily pay for his expert mods.
Feymous
Post by Feymous » Fri Aug 12, 2016 7:26 pm
Very cool ideas William!! Thanks for sharing.
I don't have the tools to cut my DF pieces, but I'm definitely going to "borrow" the creative uses for the assassins perch. :D
Post by William » Tue Aug 09, 2016 6:54 am
Here are the other ideas -
Using the Assasin's Perch to mount a sign on a roof. Depending on the way the magnets are set into both the sign and perch matter. If they are not compatable the magnets will be atracted together, in order to work well the sign magnet should rather stick to the wood platform or other side with criss-cross wood. A;so the perch platform edge that sticks out can be a problem. Good Luck
Ss1 Sloped Roof Sign 01.jpg (148.59 KiB) Viewed 6266 times
Ss2 Sloped Roof Sign 02.jpg (190.47 KiB) Viewed 6266 times
Ss3 Sloped Roof Sign 03.jpg (185.46 KiB) Viewed 6266 times
Ss4 Sloped Roof Sign 04.jpg (126.57 KiB) Viewed 6266 times
I modded one perch to fit better by removing a portion of the platform edge and greenstuffed a tiny bit.
Ss5 Sloped Roof Sign 05.jpg (171.13 KiB) Viewed 6266 times
Ss6 Sloped Roof Sign 06.jpg (150.79 KiB) Viewed 6266 times
Ss7 Sloped Roof Sign 07.jpg (165.76 KiB) Viewed 6266 times
Assasin's Perch roof signs and such.
Roof Sign Rest1.jpg (95.01 KiB) Viewed 6266 times
Ridge Rest1.jpg (111.88 KiB) Viewed 6266 times
Here I used a full roof plate to help support the cantilevered building.
Metal Plate Support.jpg (157.56 KiB) Viewed 6266 times
Assasin's Perch eave roofs - these to magnetic wall -
Eave Roof Idea 01.JPG (127.92 KiB) Viewed 6266 times
Eave Roof Idea 02.JPG (171.77 KiB) Viewed 6266 times
These to a metal plate or possibly the longer nail file -
Eave Roof Idea 03.JPG (171.69 KiB) Viewed 6266 times
Eave Roof Idea 04.JPG (154.32 KiB) Viewed 6266 times
Modders or anyone with ideas add some pictures or thoughts :idea: , please... I'm running out of stuff. :) Not really, but I will take some time off for a few days. :P
Josh, you can add some pictures of mods you've done or just links to your posts would be good.
Anyone. I'm going for an all-in-one idea thread for CBS tips and mods. :| :?:
Post by William » Tue Aug 09, 2016 5:55 am
Josh, I noticed your corner cut when you posted the pictures. It's a neat idea, but I was pondering the way to close it off without a 135 degree post/wall combo. Kinda tough to do without custom pieces. The easy thing about the 2x4 floors is you just have to cut a wall down the middle and your there. Although the open 1/2 wall connection can pivot like a door when you bump it, so I can't wait for the next CBS KS to add these with the 'V' for 1/2 walls.
C-mon Rune, with the metal plates in place, they just guide your knife right down the ridgeline, it's the thick gable walls that were hard. Also removing the bottom plates was a pain with a few of them and I even had quite a few roofs to choose from. I tweeked them all to see if any were not glue as well as others and found about 5 that poped a corner or two while testing.
Tips, Tricks, Mods #4
Different ways to mount Signs and other things about the CBS Magnetic Pieces.
First off - Metal plates and nail files (what?)
My group of signs from KS3 stuck to those metal plates from the roofs.
Magnetic Signs 001.jpg (128.42 KiB) Viewed 6235 times
The Plates and nail file in upper right corner
Magnetic Signs 002.jpg (173.65 KiB) Viewed 6235 times
Nail files do work - think anything metal and thin set between floors.
Magnetic Signs 003.jpg (150.6 KiB) Viewed 6235 times
Magnetic Signs 004.jpg (128.95 KiB) Viewed 6235 times
Just a fun picture?
Magnetic Signs 005.JPG (102.25 KiB) Viewed 6235 times
These are all stuck to plates between floors.
Sm1 Metal Plate Under Floor 01.jpg (130.05 KiB) Viewed 6235 times
Sm2 Metal Plate Under Floor 02.jpg (114.78 KiB) Viewed 6235 times
Here is a sign I modded to make it look as if a chain broke and the sign is hanging off, the only problem is the ABS has memory and keeps wanting to repair itself. I think I'll just cut it off and loop a wire link to hang the sign from one side.
Sm3 Metal Plate Under Floor 03.jpg (136.98 KiB) Viewed 6235 times
Small plate at corner for corner signs. Could be a thinner playe so it doesm't stick out as much as this one from the 1/2 roofs. I stuck the shields on to hide the plates from the sides, but a plate the width of the magnet would be great. The nail files are narrow, but have a rounded end so it might not hold good enough. I don't really know, because I didn't try it.
Sc1 Corner Sign 01.jpg (238.15 KiB) Viewed 6235 times
Sc2 Corner Sign 02.jpg (147.08 KiB) Viewed 6235 times
Sc3 Corner Sign 03.jpg (130.88 KiB) Viewed 6235 times
Sc4 Corner Sign 04.jpg (152.33 KiB) Viewed 6235 times
Sc5 Corner Sign 05.jpg (151.31 KiB) Viewed 6235 times
If your magnet fell out, you can use a stick pin and still use the sign.
Sp1 No Mag - Pin Sign 01.jpg (142.14 KiB) Viewed 6235 times
Sp2 No Mag - Pin Sign 02.jpg (140.65 KiB) Viewed 6235 times
Sp3 No Mag - Pin Sign 03.jpg (105.68 KiB) Viewed 6235 times
Sp4 No Mag - Pin Sign 04.jpg (161.04 KiB) Viewed 6235 times
Sp5 No Mag - Pin Sign 05.jpg (138.91 KiB) Viewed 6235 times
What about a paper clip instead of a magnetic wall? I made these quickly to show idea and realised I made them a bit long, so I would make them a shorter length if I really were to use them. I would also make them straighter and paint them stucco to blend in.
Sl1 Metal Paper Clip Hanger 01.jpg (139.94 KiB) Viewed 6235 times
Sl2 Metal Paper Clip Hanger 02.jpg (102.31 KiB) Viewed 6235 times
Sl3 Metal Paper Clip Hanger 03.jpg (134.7 KiB) Viewed 6235 times
Sl4 Metal Paper Clip Hanger 04.jpg (142.73 KiB) Viewed 6235 times
Sl5 Metal Paper Clip Hanger 05.jpg (144.34 KiB) Viewed 6235 times
I have a few more sign ideas, but thought I would throw them in the next installment.
Please add any ideas you come up with. Till next time... :geek:
Post by Runeweaver » Sun Aug 07, 2016 10:40 pm
I like it, and it looks simple, but I think many know that it truly isn't because u need an exact cut. That takes guts, William. I'll admire it from afar, as I don't have the intestinal fortitude to hack these apart. Funny, I'm a modder and I don't think I'll undertake this project.
Post by jchunick » Sat Aug 06, 2016 10:14 pm
There are a lot of wonderful mods here. I'd love to try some out myself. I did cut the corner off one of the floor tiles, but it kind of needs some custom walls with corners now :-)
I really like your corner posts with the 1/2 cut vee so that the posts look nice and square, and the vee is only needed for the railing.
Post by William » Sat Aug 06, 2016 10:00 pm
I've lied, I will be doing the signage post next. There is a reason I have to show this mod first and I will point it out as we go.
Edit - I would have posted pictures of these proccesses, but my computer died awhile back and I lost the photos. Remember to BACK UP YOUR SYSTEM...
Tip/Mod #3 - Shed, 1/2 Roof -
I wanted a way to cover a 40' (or wider) floor with something that would slope up to the next level. I've seen large roofs done with an upside down roof over two side by side then the final roof covers the one fliped upsidedown. What a waste of roofs. I also wanted to use the space upstairs, so I cut a roof down the ridge to cover the 10' area to each side of the upstairs.
Roof Mods 001.jpg (170.3 KiB) Viewed 6002 times
Roof Mods 002.jpg (133 KiB) Viewed 6002 times
When I removed the plastic plate set into the bottom of the roofs and 1/2 roofs I noticed the metal plates for the magnetics was just glued in place under the two roof planes. It's fairly easy to avoid the plates when only cutting down the ridge with an X-Acto or utility knife. To fit the new shed roof under the eave above, you will need to shave/cut down top the about 3/16" or so. Then it should slide under without picking up that side of the roof above it. The Gable End Walls are pretty thick, but just rock back and forth on them and it will work. Good Luck if you try.
Roof Mods 003.jpg (131.03 KiB) Viewed 6002 times
I also cut Four Tudor walls and 2 Wood Floors in half to mix things up. I couldn't wait for the new CBS coming in the Castle KS and upcoming KS's. I needed the flexability in design. :geek:
Roof Mods 004.jpg (164.72 KiB) Viewed 6002 times
Roof Mods 005.jpg (147.88 KiB) Viewed 6002 times
I also made a half railing for other reasons,...
Railing Cut1.jpg (179.84 KiB) Viewed 6002 times
...but it fit here nicely.
Roof Mods 006.jpg (152.06 KiB) Viewed 6002 times
Edit - "Yes, I trimmed four posts for just railings. I've got a serious problem here!"
On these two 1/2 roofs and one full roof I have removed the metal plates to cut those into hip pieces (I've not had the guts to try it yet, but I will get them done someday.)
Roof Mods 007.jpg (128.7 KiB) Viewed 6002 times
Roof Mods 008.jpg (94.7 KiB) Viewed 6002 times
Difference - with or without.
Roof Mods 009.jpg (109.39 KiB) Viewed 6002 times
Now that I have shown you where these metal plates have come from, I'll get back to the signage post. Next time................................................. ;)
Post by Vegomatic » Sun Jul 31, 2016 11:38 pm
Excellent tips!
Looking forward to more!!!
Post by Runeweaver » Sun Jul 31, 2016 10:58 pm
Very easy to do. I may have to do that. Keep them coming, William!
Post by William » Sun Jul 31, 2016 3:52 am
Thanks guys, I just love sharing the ideas I see or come up with (I love seeing your ideas too). Kitenerd, you're always so good with story side of things, you must be a veracious reader. Great story line there, the Bronze Lion - Protector of Valoria. I was just thinking of a baddie, but a goodie works too.
Anyway -
TIP #2 - Adding PUNCH to the interior lighting of your buildings, when viewing from outside.
Paint the underside (CEILING) of the Floors and Roofs to relfect more light. I used Pokorny White and Pokorny Cardboard on the underside of Ceilings that might be exposed if viewed from below like a deck or balcony. As you will see in the photos I screwed up with one open area below two floors, one is white and the other is cardboard. Oops :lol: This is a project anyone can do and with any type paint. These took two coats to look decent, but it's not really for viewing anyway.
Floor Ceilings - (Yes, some are modified, I'll get into those at a later date.)
Roof Ceilings - (Yes, ...)
Partial Roofs (Cut down ridgeline) still have metal plate inside for magnetics and reflection of light, no paint. I'll show these in use soon.
Baseline - Two rooms similar walls for reflection of lighting.
Examples of open light on ceilings with and without white paint.
Money-Shot of the difference - TADA ... ;)
Some examples of lighting.
Where I missed the two different colored ceilings, I think it matters for brightness.
Next post on Signage, some easy ideas for various ways to mount your magnetic signs.
