Archimagus' Sanctum (Bits and Pieces)
- Archimagus
- Orc
Re: Archimagus' Sanctum (Bits and Pieces)
I use 1/4 magnets for the small pieces and 1/2 inch for the larger pieces. That seems to work pretty well. I use a drill for the small ones but have to use a dremel for the larger ones, since I don't have a 1/2 drill bit.
- Archimagus
- Orc
Next up is a piece called an Oriel, also from Thromallian. Makes a nice little piece to make a building look a little different. Used an 1/2 magnet on this one.
- Attachments
- Oriel.jpg (453.15 KiB) Viewed 6732 times
- Oriel (1).jpg (479.41 KiB) Viewed 6732 times
- Oriel (2).jpg (335.02 KiB) Viewed 6732 times
- Archimagus
- Orc
Next we have Wall Antics Giant and Wall Antics Skull. Both sets are from Thomarillion. They are made out of metal. I have to fill in the back with greenstuff and then drill it out for the magnets.
- Attachments
- Wall Antic Skull.jpg (490.98 KiB) Viewed 6250 times
- Wall Antic Giant.jpg (497.15 KiB) Viewed 6250 times
- Wall Antic Giant (1).jpg (492.69 KiB) Viewed 6250 times
- Archimagus
- Orc
Now moving on to accessories to spice up your setups. First up are some stalagmites made by Galeforce 9. The set was called Caverns of Underdark.
- Attachments
- Caverns of the Underdark (Galeforce 9).jpg (492.8 KiB) Viewed 6067 times
- Archimagus
- Orc
Now we need fungi. This is a set of fungi from Scotia Grendel called Dragon's Horns Fungi. They are made out of resin.
- Attachments
- Dragon's Horns Fungi (Scotia Grendel).jpg (528.17 KiB) Viewed 5939 times
- Dragon's Horns Fungi (Scotia Grendel) 2.jpg (537 KiB) Viewed 5939 times
- Archimagus
- Orc
The next set is also from Scotia Grendel, called Shaman's Fungi. Also made of resin.
- Attachments
- Shaman's Fungi (Scotia Grendel).jpg (516.73 KiB) Viewed 5943 times
- Archimagus
- Orc
We also have Fungi, also a set from Scotia Grendel, made of resin.
- Attachments
- Fungi (Scotia Grendel).jpg (432.46 KiB) Viewed 5855 times
- Fungi (Scotia Grendel) 2.jpg (415.79 KiB) Viewed 5855 times
- Archimagus
- Orc
These are some mushrooms that came from Wizards D&D collectible miniatures sets.
- Attachments
- Mushrooms (Wizards).jpg (535.01 KiB) Viewed 5705 times
- Archimagus
- Orc
This is a Violet Fungus from Otherworld Miniatures. It is made out of metal.
- Attachments
- Violet Fungus (Otherworld).jpg (469.6 KiB) Viewed 5548 times
- Archimagus
- Orc
No setting would be complete without some kind of dangerous plant life. These are Fantasy Forest set from Scotia Grendel. Made of resin.
- Attachments
- Fantasy Forest (Scotia Grendel).jpg (514.96 KiB) Viewed 5549 times
