Tower Cupola
Archimagus
Re: Tower Cupola
Post by Archimagus » Sun Jul 09, 2017 12:35 am
Once everything was dried, I painting it up to match KS3/KS4 stone buildings. Below are pictures of the finished piece, using some of the KS4 post items (skellys, gargoyles, etc.)
Domed Roof 12.jpg (112.45 KiB) Viewed 1111 times
Domed Roof 11.jpg (117.01 KiB) Viewed 1111 times
Domed Roof 10.jpg (110.75 KiB) Viewed 1111 times
Domed Roof 9.jpg (128.49 KiB) Viewed 1111 times
Archimagus
Tower Cupola
Post by Archimagus » Sun Jul 09, 2017 12:33 am
I purchased a tower cupola from Thomarillion. Problem is its too small to fit on DF buildings, 8 x 8 cm. While the DF standard is 4x4 inches. Below you can see the cupola on a 4x4 KS4 platform and can see the size problem.
Domed Roof 1.jpg (88.82 KiB) Viewed 1113 times
So I cut a piece of styrene 4x4 inches and then added a strip along the edges 1/4 inch thick styrene.
Domed Roof 3.jpg (75.37 KiB) Viewed 1113 times
I then added a thin coating of milliput along the edges, shaping it to resemble stonework.
Domed Roof 4.jpg (71.67 KiB) Viewed 1113 times
Domed Roof 5.jpg (85.2 KiB) Viewed 1113 times
To support some post holes, I added a piece of 1/4th styrene in each corner.
Domed Roof 6.jpg (89.17 KiB) Viewed 1113 times
I then added a thick coat of milliput to the top of the ledge all way around, shaping like stone and filling in any gaps. Once dried, I drilled some holes for placing post items from KS4.
Domed Roof 7.jpg (78.69 KiB) Viewed 1113 times
Domed Roof 8.jpg (74.77 KiB) Viewed 1113 times
