SLight correction: I verified with The Powers That Be that LONG walls can be used as bridges, for example to bridge over a first floor castle wall with one 4" section left out,where an archway or other pass-through can be added, OR, inside either blocked up on cubes or other means.zenmaster wrote:Bumping this thread while I remember it, and suggesting it should be added to or maybe even resurrected in a different forum after KS4 ends.
TLW also mentioned elsewhere that flat walls can be bridges!
The long, flat inside walls probably would work too...but I didn't think of that.
Totus KS Delendum Est
wach your 6 in my TWO nasty garderobes
