Questions for Jenney
Re: Questions for Jenney
Post by jchunick » Tue Mar 08, 2016 10:24 pm
CBS post + CBS floor = CBS post + 8x8 floor = sewer wall
The heights are all equal.
Post by Vegomatic » Tue Mar 08, 2016 9:49 pm
Will the 8x8 on CBS posts stand over sewer pieces?
Not sure that is clear... can I build a sewer and then cover it with 8x8 floors on posts (or perhaps the 8x8 platform pieces can lay directly on it)?
Arravis
Post by Arravis » Tue Mar 08, 2016 9:05 pm
That is deeply disappointing, many, many of us don't need or want all four sides of a castle. This kickstarter seems to assume that is everyone's goal unfortunately. I've invested in all 3 KSs campaigns so far but I have sadly found this one the least versatile and most frustrating by far.
Post by JenneyOC » Tue Mar 08, 2016 12:48 pm
I do not think so.
Audles
Post by Audles » Tue Mar 08, 2016 12:28 pm
@Jenney, Is there any movement on a pledge level to combine Watchtowers and the Gatehouse? Basically, a more cost effective pledge that lets people bypass the new wall system?
jonmilton
Post by jonmilton » Tue Mar 08, 2016 11:24 am
Will the eventual add-on pack to separate the towers from grand citadel also include the parts to close up the citadel? Please don't forget about that.
Limbolance
Post by Limbolance » Mon Mar 07, 2016 9:31 pm
Finally got to see KS page on a PC instead of iPhone!!!
"Schpingles" - the look makes me nervous about them being broken off. If Dwarvenite-G should need a repair or if someone wants to DIY it - what adhesive is best to use? Cutting method?
Also, it was shown how to make walls double thick on straight runs - does it work as well on corners?
The Wall Spacer block appeared to be a different height than the 2" square elevation blocks (2:35 on Nate's demo video) - is that going to be the final look or will they match up in height when building double thick walls?
Any chance of magnetized add ons for use on the Wall Spacer Blocks and Elevation Blocks (preferably specifically aimed at KS1 and KS3 lines - shelves and cabinetry, torch/lantern brackets, and fountains come quickly to mind...
Limbolance
Post by Limbolance » Mon Mar 07, 2016 7:06 pm
The ramp going up was 2 wide - didn't see the other picture as that Grand Visage drew the eye... Wow, and quick too... Thanks!
Post by jchunick » Mon Mar 07, 2016 6:17 pm
The cart from KS3 will fit through the arch of the gatehouse. I've tested it.
Post by William » Mon Mar 07, 2016 4:41 pm
LL, those are stretched rounded towers in the picture on the KS main page. Nate kind-of explains the concept in the 2+ hour launch video yesterday.
