Tower Break Out Pack(s) for Royal Stronghold?
Re: Tower Break Out Pack(s) for Royal Stronghold?
Post by GODofwar » Thu Mar 31, 2016 11:17 pm
biowizard wrote:.
Y'all better start addressing this Trog as SIR Biowizard, lackeys!
Totus KS Delendum Est
especially this one, with no purpose built garderobes
Post by biowizard » Thu Mar 31, 2016 2:49 pm
geekjeff wrote:If it's the back towers you want to breakout of the Royal Stronghold, you should not need a Tower Breakout pack. For the front towers, you would.
I stand corrected.
Post by geekjeff » Thu Mar 31, 2016 9:14 am
Having thoroughly teased apart the construction of the Royal Citadel via the parts list and photos, I can tell you that it does not use Corner Wall Platforms of any sort for the back towers at all. It uses 4x4 and 4x8 Roof Platforms for that whole double thick back wall. It also includes the "hole filler" pieces required, but you may need to improvise and steal them from other areas of the build.
zoroaster100
Post by zoroaster100 » Wed Mar 30, 2016 7:58 pm
Thanks, Biowizard!
Post by biowizard » Wed Mar 30, 2016 7:19 pm
Yes. You need two.
4 corner walls
If you could acquire four corner platforms, four 3/4 solid wall inserts & 4 solid wall inserts, that would be perfect/most economical solution for your need. There is no such add-on right now.
zoroaster100
Post by zoroaster100 » Wed Mar 30, 2016 2:42 pm
Do I need the tower break out add on to break out the towers in a Royal Stronghold? If so, how many packs do I need if I want to have all four towers stand independently?
What add-ons would I need to close up the gaps in the walls if I want to use the core castle without towers at the same time?
