Gate House Build + Motorized Assembly?
Pagus
Re: Gate House Build + Motorized Assembly?
Post by Pagus » Sun Jul 23, 2017 12:54 pm
OK that is only slightly better than my amazing pain pic ;)
Post by jchunick » Sun Jul 23, 2017 12:25 pm
Here's a step by step, in pictures:
01 (Custom).jpg (115.89 KiB) Viewed 1820 times
02 (Custom).jpg (98.02 KiB) Viewed 1820 times
03 (Custom).jpg (99.62 KiB) Viewed 1820 times
04 (Custom).jpg (108.87 KiB) Viewed 1820 times
05 (Custom).jpg (102.06 KiB) Viewed 1820 times
06 (Custom).jpg (89.24 KiB) Viewed 1820 times
Be careful when pushing in the plastic pins of the motorized winch housing into the dwarvenite wall. I found that going slow and making sure it's aligned, then pushing from the front of the gatehouse wall so you're pushing the wall holes into the pegs of the morized winch housing was better than trying to force the housing pegs into the holes. Go slow.
07 (Custom).jpg (56.47 KiB) Viewed 1820 times
While connecting the motorized winch, be careful to ensure that the bottom of the front plate (with the switch) doesn't get hung up by the lip that the unit "sits" on. It's a very tight fit. The wall is dwarvenite, so it's flexible enough to bend slightly and get the bottom of the front plate unstuck if it's held up by the lip.
08 (Custom).jpg (74.82 KiB) Viewed 1820 times
09 (Custom).jpg (85.07 KiB) Viewed 1819 times
10 (Custom).jpg (100.72 KiB) Viewed 1820 times
11 (Custom).jpg (100.43 KiB) Viewed 1820 times
12 (Custom).jpg (79.84 KiB) Viewed 1820 times
13 (Custom).jpg (97.22 KiB) Viewed 1820 times
14 (Custom).jpg (90.71 KiB) Viewed 1820 times
15 (Custom).jpg (96.82 KiB) Viewed 1820 times
16 (Custom).jpg (101.44 KiB) Viewed 1820 times
17 (Custom).jpg (76.73 KiB) Viewed 1819 times
18 (Custom).jpg (130.49 KiB) Viewed 1819 times
19 (Custom).jpg (84.95 KiB) Viewed 1820 times
20 (Custom).jpg (111.25 KiB) Viewed 1820 times
Pagus
Post by Pagus » Sun Jul 23, 2017 9:58 am
Sorry I am at work right now so I can not take a pic but I drew something rough for you. If you need more I can post real pics later today / tomorrow.
Pic is layout of bottom layers. You will fill in gaps using magnetic wall pieces and then place top spacer on unit. It should be level if you did it right.
http://freeimage.host/images/2017/07/23/gatehouse.jpg
gate house.jpg (35.31 KiB) Viewed 1826 times
radionate
Post by radionate » Sat Jul 22, 2017 7:22 pm
Can anyone post pictures on how the motorized assembly fits onto the gatehouse. I have searched the forums and DF youtube channel and they do not show how to build on top of the gatehouse. I can build everything else via the pdf building guid and vids but the gatehouse bonus stuff was not added to the how to build stuff. thanks hive mind.
Thanks in advance!!!
