What is the #1 KS4 set you would buy if it was in stock?
Re: What is the #1 KS4 set you would buy if it was in stock?
Post by Harneloot » Mon Sep 11, 2017 8:57 am
Mon Sep 11, 2017 3:15 am
There are a number of sets that don't appear at all.
Personally I think DF should show all sets even if they are not in stock.
By not showing them you cant be sure if they either exist (customers new to castles) or are never going to be restocked.
Totally agree. DF should have pictures/info on every set they ever produced, just like the Wiki does. (I think MBA does this, no?)
Post by Rabbit Burner » Mon Sep 11, 2017 3:15 am
Null
Post by Null » Sun Sep 10, 2017 11:18 pm
Large Tower Roofs & Large Round Crenellations... which not only aren't in stock, I don't see them at all!
Post by dice4hire » Mon Aug 28, 2017 11:10 pm
I am not sure what I would buy right now, I think I have enough, but did not go into towers at all. I have two small crenellations to work with my curved wall pieces from KSI, which work GREAT together, so I suppose I would not mind a small tower roofs. I waited too long on those.
Post by Rabbit Burner » Mon Aug 28, 2017 4:11 pm
Had no real QC problems other than magnets dropping out - now I always have some superglue handy when unpacking DF.
I had to get more tower floor pieces as I found for tall towers integrated into double height walls or higher I needed more 1" extension pieces https://shop.dwarvenforge.com/products/1-extensions
and alternative floors https://shop.dwarvenforge.com/products/alternate-floors
I don't find the Pacman piece a big problem, I like my towers sturdy :)
Agree with walls - I got plenty and could easily use more ;)
Understand how they sold out so quick - don't forget ruined walls make up a whole wall.
Post by AnimeSensei » Mon Aug 28, 2017 2:35 pm
Sad, but I understand. QC has been inconsistent starting in KS3.
Post by Oldent » Mon Aug 28, 2017 9:11 am
The poor fit,inconstant scale,loose connections,lost magnets were all things I could work around. Sold out necessary parts was the last straw. I got rid of mine.So NO castle parts of any kind
Post by AnimeSensei » Sun Aug 27, 2017 11:40 pm
Corners
Thunder
Post by Thunder » Sun Aug 27, 2017 10:38 pm
Long Walls.
I went big on Towers and Themed stuff and just figured I would have enough walls - nope. You actually need a lot of pieces to build a decent length of wall.
I think there was an earlier forum post a few months ago with pretty much the same subject.
Post by GODofwar » Sun Aug 27, 2017 10:19 pm
Kobolds, yah. I'm suckering.
Totus KS Delenda Sunt, except KS 5
