Removing Towers from the Royal Stronghold
Re: Removing Towers from the Royal Stronghold
Post by LadySabelle » Sun Sep 30, 2018 7:05 pm
You need two of these Large Tower Breakout packs if you want to remove all 4 large towers. https://shop.dwarvenforge.com/collectio ... r-breakout
You can fill the cutout space of the outside corners with the wall inserts that come with the RS, but if you want solid walls you'll need those corners you linked to.
Post by astolat » Sat Sep 29, 2018 10:16 pm
I'm pretty sure you want the corner walls and the large tower breakout packs. You might also want crenellations/battlements for the corner walls if you have them for the rest of the walls.
Tenbears
Post by Tenbears » Sat Sep 29, 2018 5:42 pm
So this question really has two parts.
1) I dont think the Royal Stronghold package comes with the pieces to square off and not use corner towers. By that I mean I want to break out the tower and have a 90 degree corner on the castle with finished walls. Stefan I think has a photo of something on facebook right now where there are no towers on the back two corners, two on the front corners of it, and one large free standing tower in the middle. Is there a breakout pack for doing this? I found this one but not sure tbh if it does what I need (or if i even need it at all):
https://shop.dwarvenforge.com/collectio ... rner-walls
2) I also don't think that if you remove the towers from the corners that you have enough pieces to finish each tower and have a free standing tower. Pretty sure there IS a pack for this but want to make sure that I am not buying something that I don't need.
Help appreciated!
TBears
