KS5 - Magnets in bases
Re: KS5 - Magnets in bases
Post by kitenerd » Wed Oct 10, 2018 1:37 pm
OK - I am officially a convert!
Just magnetized a trial set of caverns and sewers (which have lots of bits and really benefit from sticking together) and i am going to order a ton of more magnets and magnetize EVERYTHING
terrible picture, but this is a terrain tray held VERTICALLY with my sewers and caverns bits on it
game changer for me who lacks the area to leave anything set up
I used 10mm x 2mm ZD2 and 7/16" x 1/32" ZD701 from K&J magnetics
ZD2 = 25 for 8.50 (surplus)
ZD701 = 20cents each
I also have a sample coming from eBay that were half that price - which considering how many hundreds i need might be worth waiting extra time for
my experience - there is a LOT of variation in the recesses on the bottom of the pieces - it doesn't matter - the magnets do not need to be flush, the field is strong enough that they hold
i put them on with a glop of glue the size of a pea (gorilla contruction adhesive - edit: this failed - seeking other glue) and pushed them until they sank in - made sure they were flatish and below the tile edges with a popsicle stick which i passed over in both directions in profile like a level
that is a significant gap and the only piece i had that fell off (held vertically which is not how i intend to use my DF!) was one of the wavy cavern walls (which are pretty heavy) - i only used one magnet on each piece
The big thing is having enough space to lay out pieces to dry - while it didn't happen to me - i can see magnets jumping out of the glue to hang out with their friends - these are strong little magnets!
thanks to those who blazed this trail - this is really making DF much more practical for me to use
Thunder
Post by Thunder » Wed Jul 19, 2017 9:53 pm
My local Home Depot had precut 12 x 12 inch "weldable steel" in 22 gauge for $6 each. I looked for 20 gauge but they did not have it.
The 22 gauge does flex a bit, but certainly not enough to worry about. Magnets stick quite well to it, so does Blu-Tak which I might use instead of magnets. The edges are a bit sharp, but a quick run around the edge with a file ought to fix that quick. I will also likely round the corners a bit.
Printed or painted fabrics to cover this is likely preferable, from both a visual and handling aspect - but then of course the Blu-Tak won't work.
Damn, now look what you got me started on! :)
Peace
Post by astolat » Wed Jul 19, 2017 10:55 am
Thunder wrote:
Wed Jul 19, 2017 10:35 am
I wonder how easy it would be to print 12x12 acid/lava/water textures on fabric. Of course instead of doing all this I may as well just buy the DF terrain trays....
You can print any digital texture file you have on a variety of fabrics at spoonflower. That said, I am also reaching the same conclusion, the only reason I wouldn't just get the DF trays is because having gotten the idea I now want them immediately, lol.
Stormfury, would you be able to post a pic of a side view of the tray and maybe tiles on a tray next to tiles not on a tray? Just wondering about thickness -- IIRC Nate said 22ga is what the DF trays are, but oddly the 20ga is cheaper (on metalsdepot anyway) and presumably can support even more weight, so would go with that if it doesn't "bump" too much.
Thunder
Post by Thunder » Wed Jul 19, 2017 10:35 am
We are moving further and further from the topic "KS5 - Magnets in Bases". :)
I also like the roiling boil look, it's active, aggressive and organic looking. The fabric texture really helps with the illusion.
Oldent - wonderful stuff yer doing there, especially the felt painting. I might try some of that myself.
Peace
Post by William » Wed Jul 19, 2017 9:50 am
Although I do like the roiling look of the acid bath itself.
Acid Bath.jpg (157.89 KiB) Viewed 6867 times
Post by Oldent » Wed Jul 19, 2017 9:44 am
Thunder wrote:
Tue Jul 18, 2017 11:35 pm
That's great, thanks for the reply.
I could probably use a Dremel to round the corners a bit. Looks like i ought to make an order myself.
Peace
A file would work better. The sharp edge of the sheet metal will cut sandpaper. A hand held round power tool sander will bonce and possibly ruin the straight edge.
Dremel has some nice accessories. I have the tool sharpener. I don't use it. I have a large flat mill bastard file I use for lawnmower blades, axes, grass knives and such.I have a set of small hobby files too.
If you have the proper Dremel accessories by all means use them.
Post by Oldent » Wed Jul 19, 2017 9:24 am
I wanted to illustrate the suggested sponge painting technique.I made this 1' by 1' as a photo prop from plywood. The base coat was a left over Olive green.
You can use this technique on felt. I painted a emerel sheet olive and over stamped it. Of course you can start with olive colored or tan felt. Pin it down to keep it flat. Brush it with a hair brush when it is dry. I don't care for card board terrain . This is a replacement tile for the Rune Wars forest marker.
The Skuzzy matt was also painted with sponges and finished with a dry brush. This is a sample of the sponges I have collected over the years. Natural are often better. I often cut worn out wash up sponges and make stamps. Bath sponges are more cost effective than art supply.
Thunder
Post by Thunder » Tue Jul 18, 2017 11:35 pm
Peace
Stormfury
Post by Stormfury » Tue Jul 18, 2017 10:02 pm
Thunder wrote:
Sun Jul 16, 2017 7:17 pm
That's Awesome Stormfury.
How is the flex on the sheets you bought? If you put four pillar under the corners underneath and a simple four corners room in the middle on top, how much does the sheet bow?
Are the corners and edges sharp, or have they been smoothed/sanded down a bit?
Peace
They are actually pretty sturdy. I put 24 cavern wall pieces on one while holding it with 1 hand and there was no bowing at all, so it should work as an elevated floor, though I hadn't really thought/planned to do that. I feel good that they could be used that way.
As to the edges they are not sharp, corners can be a bit. That said, I wouldn't want to drop it on a foot/toe. :) I'm really pleased with the sheets as it'll make my dungeons easier to display to players 12" at a time. :)
Thunder
Post by Thunder » Sun Jul 16, 2017 7:17 pm
Peace
