KS5 - Magnets in bases
Re: KS5 - Magnets in bases
Post by LadySabelle » Sat Jun 17, 2017 1:08 pm
jgt4242 wrote:
Sat Jun 17, 2017 12:45 pm
Different subject, but do you know what pieces are classic Dwarvenite and what are Dwarvenite-G?
The elevation platform (box) will be Dwarvenite-G and possibly some of the large 8x8 floors (not 100% sure on floors yet).
Post by kitenerd » Sat Jun 17, 2017 1:02 pm
LadySabelle wrote:
Sat Jun 17, 2017 11:57 am
The Classic Dungeon walls will have the anchor ports. The pieces available in the KS are all new. "Classic" just refers to the plain wall design rather than the vaulted walls with the columns.
The only thing better than the quick response is when you get the exact response you want to hear quickly !!!!
Thank you!
Post by Oldent » Sat Jun 17, 2017 12:56 pm
LadySabelle wrote:
Sat Jun 17, 2017 12:25 pm
Do you mean the "Passage walls"? I'm probably not the best person to answer this question, since I wasn't in on the planning for these pieces but I'll give it a shot.The passage walls are the full height of a normal wall w/floor. The "tab" is designed to slide under a floor piece so that they don't tip over. They allow you to make a narrow passage with a full grid rather than having the wall take up half a square.
jgt4242
Post by jgt4242 » Sat Jun 17, 2017 12:45 pm
Post by geekjeff » Sat Jun 17, 2017 12:31 pm
They also allow you to use special floors (hello spike traps) in the middle of a 10ft corridor, which is now possible with the old funky corridor design.
They're like freestanding walls with a kickstand that tucks under the adjoining piece for stability.
Post by LadySabelle » Sat Jun 17, 2017 12:25 pm
Post by Oldent » Sat Jun 17, 2017 11:59 am
Can you explain the tab on some of the wall sections :?:
Post by LadySabelle » Sat Jun 17, 2017 11:57 am
Post by kitenerd » Sat Jun 17, 2017 11:53 am
I would like to start a thread to get official word from DF as to which pieces have the anchor magnet system in the base. Specifically there are a lot of "Classic Dungeon Walls" in my pledge levels. Will these be remade with the Anchor Magnet System or are they identical to the hundreds i already own?
