Encounter 9 - Eldritch Pools
Re: Encounter 9 - Eldritch Pools
Post by JenneyOC » Tue Jul 04, 2017 12:59 pm
SIZE estimate for EP encounter:
Eldritch pools is a little weirder to count.
1) It's built with a lot of it on the diagonal.
2) It's actually two separate pieces.
However, if you put them end to end as shown in the picture, it takes up 18" x 24" (rounded)
Post by JenneyOC » Tue Jun 20, 2017 11:44 pm
Q: Why is the classic curved dungeon corner w/LED from encounter 9, missing a floor square? It's not like a standard 2x2 curved corner?
A: Its so you can put a floortile centered in it, or other advanced-buildery things. In Room #9, the trapdoor floors are centered within the curved alcove it creates.
Post by JenneyOC » Sun Jun 18, 2017 10:38 pm
Q: how is the Eldritch Pool handled for an unpainted pledge?
A: some of the pieces will be case in clear/translucent Dwarvenite (whether in the painted or unpainted sets). Painting translucent parts usually means using multiple layers/thick,dark paint (on the parts you don't want light to shine through); on the actual translucent parts where the light will show (like if you want to add some more orange to a flame, say) you can use a variety of different paints. LEDs are bright enough to shine through most standard hobby paints, especially light colored ones.
Return to “Codex Valoria”
Users browsing this forum: No registered users and 12 guests
