Encounter 14 - Khri Colony
Re: Encounter 14 - Khri Colony
Post by JenneyOC » Tue Jul 04, 2017 12:45 pm
Burrows: https://www.youtube.com/watch?v=MJpmCGJOAjQ
SIZE estimate: Burrows are hardest of all to tell, but I believe the encounter is 30"x18"
Post by JenneyOC » Tue Jul 04, 2017 12:44 pm
Q: I've examined the pictures in the elevation add on pack and I'm not sure what is keeping the straight "bridge" piece up between the two ramps. Are they magnetized? Is something else at work here?
A: the ramp tips are pinned into the straight burrow piece. See images within this FAQ thread of those pins.
Q: Will the egg and web inserts look good dropped on any spot, other than the holes?
A: potentially. The web may work even better because it doesn’t have a rim, but it could work.
Q: what pieces are male (with pin) and female (w/o pin)
A: From Nate:
Everything is female. The only two male pieces are the end caps and the ramp tips.
Also there are magnets in the bottom of the burrows. And metal in the tops of the stilts.
Post by JenneyOC » Sat Jun 24, 2017 9:25 pm
Q: The large pictures of the Burrows are how many sets approximately?
A: No idea - all the prototypes we had on hand
Q: Do the burrow have magnetic walls at all, where can the glyph go?
A: No, it's just lying on the floor. The Khri scavenged it
Q: How does the Bridge stay elevated, and the small endcaps stay in place?
A: There is a peg system to interlock some of the pieces to assist in elevations and keeping the endcaps in place. See the following images:
Photo Jun 24, 8 15 03 PM.jpg (121.88 KiB) Viewed 1685 times
Photo Jun 24, 8 14 23 PM.jpg (105.08 KiB) Viewed 1685 times
Post by JenneyOC » Sun Jun 18, 2017 10:43 pm
Q: Still a little put off by the lack of an apparent grid though..
A: when you see them more clearly it might change your mind about the lack of a grid
Stefan - Grid not needed, as the roots indicate the squares
