Encounter 15 - Shrine of Sysuul
Re: Encounter 15 - Shrine of Sysuul
Post by JenneyOC » Tue Jul 04, 2017 1:13 pm
Post by JenneyOC » Sun Jun 18, 2017 10:44 pm
Q: Can the jade columns be drilled out to hold a LED? Are the bases wide enough?
A: (Jeff) they might not be wide enough to hold a standard CR2032 battery and holder, but you might be able to use smaller watch batteries. I applaud modding, but please consider testing your drilling on a non-Jade pillar first! Easy to putty over if it goes bad and not limited edition.
A: (Tobi) the base is wide enough (2"x2" octogonal base), so if you want you could drill it out and put all the LED components in there. could look really cool!
Q: twisted snake pillars. Are they detachable from the floor? With a post hole in the floor?
A: the pillars in the floor pillars are not detachable
Q: do you have the list of pieces Nate said were Jade cast? That would be awesome to put in the Shrine FAQ section.
A: (quick look by Jeff)
- Wall
- Corner
- 6" long Shrine Wall
- Ancient Pillar
- Halo for Forsaken Dais
- flames for Brazier and Idol"
