Q/A - Back Compatability
Re: Q/A - Back Compatability
Post by JenneyOC » Tue Jul 04, 2017 12:30 pm
Q: On the Classic LED Curved Corners, do the KS1 curved half floors fit behind them to make it a full 2" square floor?
A: Yes
Post by JenneyOC » Thu Jun 22, 2017 10:11 pm
Q: Will the sewer tiles from KS3 fit under the elevation arches?
A: I haven't tried this yet. They most definitely will if the arches are on a floor tile. Not sure without the tile. We'll try it out and let you know.
Q: Solid Wall Insert that fits in the Vaulted Open Arch Wall, will it also fit in our old Portcullis from KS1?
A: Yes! We made sure they all shared the same dimensions so they would be interchangeable. So you can use the KS1 portcullis in the new Open Arch Wall, and all the inserts for that wall in the old portcullis arch.
Q: Will the paint job on KS5 bricks match the simpler KS1 shading, or the fancier KS3/5 shading drybrush techniques?
A: The paint job on KS5 is designed to look best with other KS1 pieces.
Q: Any recommendations for combining these dungeon sets with caverns? Any good transitional pieces?
A: The 2x4 Breached Wall is a great transition into Caverns (or into the new Burrows). We also have another transition piece that will be unveiled with the Burrows as well.
The ledges also could work to transition Dungeon floors into Caverns floors
And finally the Snake Head Arch from the Caverns Wicked Additions set would be a great transition between The Forsaken Temple and Caverns.
Q: Will the stone block pattern on these new walls align with that of the KS 1 walls ?
A: Yes! These pieces were specifically sculpted to have the stonework line up nicely with KS1 bricks.
Q: what is different about the 'newer style of bricks' compared to the original KS1 bricks?
A: The new bricks have finer detail. And the edges of the floors now have a brick pattern.
Post by JenneyOC » Wed Jun 21, 2017 3:27 am
FROM 06/20/17 LIVESTREAM
Q: Is the KS5 factory paint plan to match the factory pain scheme from KS1?
A: Yes we are trying to make everything compatible with KS1, with the addition of reddish pillars. We want them to match and do that.
Post by JenneyOC » Tue Jun 20, 2017 11:38 pm
Q: is the 'Stair Jack' piece essentially identical (even if a different sculpt) to the 'Small Stair' from KS1, or are the sizes different? Can the pieces be used interchangeably?
A: the stair jack is not the same piece, it has more steps. It can be used as a short steps (not as short as last year), or it can be inverted and used as a miniatures stand on the dais pieces.
