Q/A - LEDs
Q/A - LEDs
Post by JenneyOC » Tue Jul 04, 2017 12:34 pm
Q: Any all Led packs ?
A: Very distinct possibilities that LED packs are coming.
Q: On the Classic LED Curved Corners, do the KS1 curved half floors fit behind them to make it a full 2" square floor?
A: Yes
Q: this is actually a KS4 question more than KS5, but I assume you'll be using the same LEDs for both. Can you say what kind of LEDs you guys use -- size and voltage etc? I'm specifically interested in the KS4 LED walls with the sockets that can take either torches or runestones but any of the accessories.
A: It's a 3 volt button cell battery (CR2032) that's used in all the LED pieces. You can light most LEDs from that, from a 1.8mm to a 10mm LED, and even tiny surface mount LEDs.
