Large Curved Wall with KS4 Batter Base?
Re: Large Curved Wall with KS4 Batter Base?
Post by GardenDM » Sun Mar 10, 2019 6:28 pm
Looks like you might be able to integrate it into an inside/outside build as a dungeon entrance...
Or, if you wanted a larger than 6" tower, you could use multiple circular rooms, one for each floor laid out next to each other for easy access. This would be the entrance to the tower on the ground floor.
Post by nielsene » Sun Mar 10, 2019 10:42 am
Here you go. Not perfect because batter base assume a 6" tower, while the larger curved wall is an 8" diameter circle. Using one piece problem is fine, you won't be able to use a full circle (and I couldn't find a full circle worth in my pile of tower parts
Post by nielsene » Sun Mar 10, 2019 10:35 am
Let me go see if I can find both pieces... my castle stuff is in complete disarray.
jgt4242
Post by jgt4242 » Sun Mar 10, 2019 9:17 am
Does someone have Large Curved Wall from DoD and some Large Batter Base from KS4?
I'd like to see a picture of those two sets together to see if they fit well.
Thanks in advance to anyone who could do that for me. :D
