Eldritch Portal Inserts
Gargs454
Re: Eldritch Portal Inserts
Post by Gargs454 » Mon Apr 22, 2019 11:34 am
May have to try to dig up some of those vallejo paints. ;P
Just a quick note, the Reaper Clears are good, but not, technically transparent. They do make good glazes though, so in thinking about it, they should work just fine, just may need to thin them down. Of course, it should likely go without saying that practicing first on something you can discard is a good idea.
Post by kitenerd » Sat Apr 20, 2019 11:10 am
those transparent paints are magical, i use them over opaque just to punch up colors and do shading effects - super easy
RisingSeraph
Post by RisingSeraph » Thu Apr 18, 2019 5:13 pm
John D wrote:
Thu Apr 18, 2019 3:03 pm
RisingSeraph wrote:
Thu Apr 18, 2019 2:50 pm
Vegomatic wrote:
Tue Apr 16, 2019 5:52 pm
Reaper has a few "clear" paints as well.
Tue Apr 16, 2019 1:01 pm
Tamiya also does clear paints.
Thanks for the tip! I've been looking for more of these pigment-less / clear colors, especially purple. I bet they'll do well for anything "eldritch" themed.
Reaper Clears are good - 09099 is Clear Purple.
Also, Vallejo Model Color 'Transparent' line is great, and I use Vall Game Inks too.
Good stuff! I've been using Vallejo for years and had no idea they had a transparent line! Highly prefer their and Reaper's bottles to GW's for...obvious reasons :roll:
John D
Post by John D » Thu Apr 18, 2019 3:03 pm
RisingSeraph
Post by RisingSeraph » Thu Apr 18, 2019 2:50 pm
Post by Vegomatic » Tue Apr 16, 2019 5:52 pm
Post by AnimeSensei » Tue Apr 16, 2019 1:01 pm
102 Resin and 232 Dwarvenite Sets/Packs Owned
RisingSeraph
Post by RisingSeraph » Tue Apr 16, 2019 11:51 am
Gargs454 wrote:
Mon Apr 15, 2019 4:53 pm
So related question as I see that last pic, and related to the obelisks, etc., How do you go about painting them in a way to continue to allow the light to come through? Just really thin layers? Almost like a glaze? Never painted anything translucent before.
I've just started experimenting with this myself. A very thin / wash layer seems to be the trick. Citadel also makes a line of "Gemstone" technical paints which are very translucent (Spiritstone Red, Waystone Green, Soulstone Blue, and Blood for the Blood God if you want a darker red). I've used "Blood for the Blood God" on the crystals for one of the smaller portal pieces and immediately fell in love with the effect. I've also used it with a white base for a pretty convincing gem effect for the eyes on the Dungeon of Doom braziers and the eyes of the golems. I'm planning to do more with it, will post pictures if I'm able.
Gargs454
Post by Gargs454 » Mon Apr 15, 2019 4:53 pm
John D
Post by John D » Tue Apr 09, 2019 8:09 pm
Thanks, Rabbits. :D
I like this take on the portals (from Tobi's new Builder's Masterclass page) -
When I get another Eldritch Pool set, I might try to make better use of the translucency.
I thought Blue might seem too much like water, but it does seem rather 'magical' here....
Users browsing this forum: No registered users and 21 guests
