Suggestions from the peanut gallery
Re: Suggestions from the peanut gallery
Post by Rabbit Burner » Mon Mar 05, 2018 9:28 am
Ok just took a trip to thunderbolt city !
Apologies if you have read this on another forum post but bear with us.
We realise that all the 8x8 (we assume its the same for 4x4 too but at work so cannot verify) that you can use CBS posts to raise them up and then someone pointed out you can use CBS wall in between your posts creating a building.
Or .... if you had Mountain, Dungeon and Cavern CBS walls you can create cliffs and therefore some easy walkways and a multitude of easy elevation builds
Walls could be sculpted and therefore textured to be Dungeon walls (though probably similar to stone CBS walls) or Mountain walls to give you easy cliff faces and for KSVI Cavern walls.
But you could go next level and have mined walls, ruined walls, led walls, themed walls Dwarf, Drow etc.
You could combine a mined cliff wall with some magnetic scaffolding and lift mechanism ..... just don't delve too deep....
+ 34 to new CBS style walls for Mountain, Dungeon and Caverns
Post by William » Sat Mar 03, 2018 12:48 am
From box at top of page below header - click on the 'here' above.
The one in next line does not work it's just an example.
......................................................................More forum instructions are here.
I usually save as .jpg and the file size is fairly small, so 680 max. either direction works usually.
Post by kitenerd » Sat Mar 03, 2018 12:30 am
With the puzzles i discovered that the forum is less fussy about pixel dimension than it is about file size. By lowering the quality from max to good ( jpg setting when saving in photoshop) i was able to post much larger images than i thought possible.
Post by GODofwar » Fri Mar 02, 2018 10:54 am
Thu Mar 01, 2018 11:56 pm
I use this site ro resize and make smaller file sizes.
http://jpeg-optimizer.com/
Thank you, Dice.
Post by dice4hire » Thu Mar 01, 2018 11:56 pm
Post by GODofwar » Thu Mar 01, 2018 11:33 pm
bernyleung wrote:
Thu Mar 01, 2018 10:57 pm
I just use good ol' Microsoft Picture Manager, resize to 640x480, save, post, link.
Never heard of it! I bet Youngest Offspring has, though.
Thak you, Berny!
Post by bernyleung » Thu Mar 01, 2018 10:57 pm
Post by GODofwar » Thu Mar 01, 2018 9:56 pm
Tried Imgur. I'm not getting something. Could not drop images there - they wouldn't take.
Can't find my resizing instructions.
Damn.
Post by Oldent » Thu Mar 01, 2018 4:19 pm
I think the levels discusion is interesting. I will add some comments latter. I am late for game night.
I want to lobby for a PVC version of the old log bridge.
I made 24 4 by 4 inch lava tiles for Massive darkness. I also like to use backdrops and facides to create illusions of height.
Post by GODofwar » Thu Mar 01, 2018 4:01 pm
One problem with the level system I didn't foresee (because I can't mentally project from 2d to 3d and don't think that way) was that all multilevel sets have to be built from the bottom up...the reverse of the way the script runs, in most cases.
I have a set of standard table map forms I put in plastic. I can plan the surface - or whatever layer the adventure starts on - and then figure out which plate is above/below and build the next layer accordingly.
It is not tremendously fussy. I just need to be sure all the terrain pieces will fit more or less, but the planning aids make that possible.
Tall objects (anything taller than standard DwF height caverns or dungeons) either lay down in negative space next to the place they go, or have a small Post-It note on the set with a number, keyed to the working table beneath Fly Table #2. I just go find that number and put the terrain piece in when the PC arrive.
Usually don't put monsters down ahead of time, and place them in the manner above, except I have a 20-deep set of cardboard grocery boxes, about 4" deep, numbered 1-20, which I use to store monsters. I usually only have one or as many as there are levels, although the one game we did on BOTH fly boards, 4 deep, I used IIRC twelve monster boxes.
Users browsing this forum: dragonlady and 5 guests
