KS6 - Puzzle Teaser
jazzman
Re: KS6 - Puzzle Teaser
Post by jazzman » Tue Jan 30, 2018 4:19 pm
I also wonder if the tight corner, if it is 1x1, can be used in conjunction with the swell walls to make a wide radius curve similar to the 4x4 curves in the resin caverns set?
jazzman
Post by jazzman » Tue Jan 30, 2018 3:44 pm
I think four of them put together would form like a volcano in the middle of a cave. Flying critter hiding spot? Large column to support a second level? Spider lair?
jazzman
Post by jazzman » Tue Jan 30, 2018 3:37 pm
I wonder if the top one, what I am calling the large convex corner, will work best with a swell wall on each side? It almost appears like it doesn't go all the way back to the corners of the floor.
Rhizom
Post by Rhizom » Tue Jan 30, 2018 12:42 pm
jazzman wrote:
Tue Jan 30, 2018 9:51 am
Can't wait to see that tight convex corner used in a stepped wall!
Furthermore, this convex corner will be exactly what I missed in KS2, where you just had two wall pieces in a 270°angle and a floorpiece in between when you needed a convex corner. Always with a gap. In a way, this new piece is what the gargoyle corner pillars were for KS5, right? (only with floor attached)
natetaylor wrote:
Tue Jan 30, 2018 11:16 am
Here's your daily dose:
This one is easy :D
Post by kodiakbear » Tue Jan 30, 2018 12:41 pm
fnordfriendly wrote:
Tue Jan 30, 2018 9:56 am
Huh. Is that bottom one right Kodiakbear? I can't wrap my head around the base... is my head wrong?
Not sure on either question. ;)
natetaylor
Post by natetaylor » Tue Jan 30, 2018 11:16 am
fnordfriendly
Post by fnordfriendly » Tue Jan 30, 2018 9:56 am
jazzman
Post by jazzman » Tue Jan 30, 2018 9:51 am
Post by dice4hire » Tue Jan 30, 2018 5:24 am
Hmm maybe 1x1 at that, good eye!!
