Is there a good magnet-containing substitute for the 37 mm tall stilt?
Riley
Re: Is there a good magnet-containing substitute for the 37 mm tall stilt?
Post by Riley » Mon Nov 12, 2018 5:18 pm
John D wrote:
Mon Nov 12, 2018 4:33 pm
I have some wood dowels to cut up (trying various heights), but I might want to use something else there.
kitenerd's suggestion of dice's foam blocks is good,
I highly recommend Dice’s foam blocks as 2” risers. Nice negative space, and sooooo much cheaper than elevation blocks.
John D
Post by John D » Mon Nov 12, 2018 4:33 pm
I picked up a few neodymium disc magnets (12mm x 3mm) yesterday, and they work pretty well. I have some wood dowels to cut up (trying various heights), but I might want to use something else there.
kitenerd's suggestion of dice's foam blocks is good, but I have a huge variety of sizes to elevate (6"x 2",3",4",6",8",10",12", and 18") for a total of 40 steel trays. A boxfull of magnetized supports of varying heights just seems like the perfect solution.
I'm still getting a couple packs of Stilts, tho.
Post by kitenerd » Mon Nov 12, 2018 3:09 pm
Closet Rod will be cheaper and thicker than dowels and it is readily available
Smart money is on finding a source for some really nice dense black foam blocks... wonder where those could be had ???
MrMorden
Post by MrMorden » Sat Nov 10, 2018 1:57 pm
You can always get some thick dowels, and cut them to 37mm length, and put magnets in the ends. Most builds will have them hidden anyway.
Riley
Post by Riley » Fri Nov 09, 2018 6:01 pm
Thanks. That’s about what I could come up with. I will certainly skip the short stilts, but the tall ones seem useful. (Partly because I have very few elevation blocks.)
Post by dice4hire » Fri Nov 09, 2018 4:55 pm
Stacked ledges from DoD like Animesensei said.
Post by AnimeSensei » Fri Nov 09, 2018 4:50 pm
3 floors? 3 chasm pieces from the DoD stacked?
Riley
Post by Riley » Fri Nov 09, 2018 4:22 pm
There is already a pretty good substitute for 12 mm stilts:
Magnet-installed floors, which can be stuck, upside-down, to the bottom of terrain trays.
For a full 50mm/2”, DF5 corner walls will serve in the same way.
Is there a similar, magnet-installed 37mm stilt-substitute? There are elevation blocks and freestanding corner walls and the like that are the right height, but offhand I can’t think of any of them that have a magnet in the base. Is there something I’m forgetting?
