Did Caverns Deep really have the basic needs?
Re: Did Caverns Deep really have the basic needs?
Post by kitenerd » Sat Oct 12, 2019 12:44 pm
subtalon wrote:
Sat Oct 12, 2019 11:09 am
unclebilly wrote:
Sat Oct 12, 2019 9:47 am
I just wish DF would go back to here is a set of A,B,C pieces and stop with their premade encounters. I was much happier with the way you could buy sets in KS 1-3. Base sets with add-ons. Each KS has gotten more expensive and confusing. I think that makes it harder for new people that want to get in on it. Where the older Doofers that have some stuff kinda know what we may want I could see where a new person would be totally lost.
I was actually the opposite. For me I saw a set of pieces and had no idea what I could do with them. Once encounters showed up in DoD, for whatever reason it clicked. And I've been buying way to much DF ever since. Enough so I may need to start an anonymous support group, unless that's what the forums are.
That said, now that I'm fully into DF, I would like as an option those straight forward pledges 10 straight walls, 10 corners, 10 floors, etc. I think we get that to some degree with the starter dungeon/cave but it has other pieces I won't used as much because I may already have them in other encounters.
In KS 1 we begged for (and got) multiple layouts of each pledge tier - it really helped those of us with NO DF comprehend what was possible with any given set of pieces. That being said those bare rooms were not nearly as seductive as the beautifully integrated encounters that basically tell the story themselves. Encounters capture the audience and create desire FAR better than 12 walls, 8 corners and 10 floors.
Post by kitenerd » Sat Oct 12, 2019 12:41 pm
I have said it 1,000 times and i will say it again:
Base sets make the most sense
Encounters generate the most sales
Build the encounters out of base sets plus packs...
Encounter 6 "Dueregar Ambush" is made up of 2 Base Cavern Packs, 1 Cavern Passage Set and 1 Passage Transition Pack
Encounter 7 "Alchemist Laboratory" is made up of 1 Base Cavern Pack and 1 Alchemist Accessories set
People who want to build them one at a time buy 5 packs and people who want the big layout buy 6, getting an extra Base set so they can build both encounters at once. Offer two top tiers one that lets you build each encounter individually and one that lets you build the whole layout.
Obviously every Encounter will not use EVERY piece in a set, but you include a graphic of the "extra leftover parts" - no one ever minded getting MORE than they planned on!
This is SOOO much simpler from a packaging, fulfillment and future inventory management standpoint that i fail to understand why it is not being done... It also enables future KS's that add only a limited number of items to "reissue/resell" previously released stock with different features and bling (like the Pathfinder encounters). They are doing this with Build of the Month and i think it is brilliant (i wonder if it generating significant sales?).
Sometimes what seems obvious is actually a good idea.
subtalon
Post by subtalon » Sat Oct 12, 2019 11:09 am
Post by unclebilly » Sat Oct 12, 2019 9:47 am
Post by Law » Sat Oct 12, 2019 6:41 am
Another issue with “basic needs” that I’ve been thinking about is - well, what do you “need” for this? In my mind, that comes up when you want something big - obviously very few pieces are “needed” if you’re doing something small. So the big question for me is: what is the advantage of a larger cavern? And there are (roughly) two ways to think of “larger” - there’s “bigger room” and there’s “more rooms.”
My sense is that even with all the off-grid and crazy build options, we still only have a limited number of wall and corner designs. Past a certain point, (1) all rooms are gonna look the same, at least close up (because the basic wall and corners, whether you’re using normal walls or trifecta walls or crooked caverns etc.) are going to repeat; and (2) all parts of a larger single room are gonna look the same close up (ditto). Basically, “large” inevitably means “what you just saw over there, but over here now.”
That means that there are basically three reasons to do a large layout:
1) Hey, some people like large layouts. A huge sprawling cavern complex can look cool.
2) For gaming purposes, although here I think for all practical purposes you’re not gonna need more than a 2’x3’ layout for most gaming sessions as it takes HOURS to go through this stuff, esp if combat is involved. But, sure, If you have tons of encounters planned and want a big cavern for a game, sure.
3). Using the encounter model - making some bling the focus of attention in each room. If you want one space to have a crystal lode, and one space to lead to the Underdark, and one space to have a rise that leads to a higher level, etc., and you don’t want that all crammed in a tiny space - you’ll need a lot. And yeah the corners and walls surrounding the focal point will repeat - and yeah you could maybe just do each of those one at a time with fewer bread and butter pieces - but sure, just like with the DoD, you may want to have this encounter model, where each area is centered around something unique but is comprised of a lot of repeated elements.
So - tl;dr - whether you have “enough” basic pieces depends IMO on why you might want more. I don’t think any of the above is NECESSARY. A large build can look cool from a distance, sure, but the cool details are repeating themselves so a small build looks just as cool close up. A large build is useful for gaming, but probably not necessary unless you’re doing a marathon game and don’t want to take the time to break down and rebuild encounter areas. And a large build is great for staging spaces for different unique bling pieces, but as above query whether you need to build all of them simultaneously.
None of this is new info, the DF team laid all this out in the reasoning behind the encounter core sets and “adventure pack” stuff. But I think all of it bears on this issue of how much “basic” pieces one needs.
Post by nielsene » Mon Oct 07, 2019 12:53 pm
The 'build encounters out of well-composed-packs' also has the benefit of making the 'Essential' style pledge tiers very easy to create.
Post by dice4hire » Mon Oct 07, 2019 4:23 am
Wonder how Wildlands will work out
Post by William » Mon Oct 07, 2019 3:03 am
Also remember..., 2 swells = 1 full. ;)
Post by Talistran » Mon Oct 07, 2019 2:52 am
Mon Oct 07, 2019 2:45 am
If you have packs with sane compositions, then Encounter XYZ is made of Pack A, B & C and the leftover parts include the Right Swell Wall
The encounter does not need to use EXACTLY every piece in the pack... just show folks what is left over in a separate graphic
Yep, exactly. It would help sell them even better than the encounter system, because now I have 7 pictures of various things I can make with a "set" of packages (Pack A, B, & C for example) instead of just one. And we'd stop having 32 Left Swell Wall with only 19 Right Swell wall situations.
Post by Talistran » Mon Oct 07, 2019 2:50 am
Mon Oct 07, 2019 1:57 am
Talistran wrote:
Mon Oct 07, 2019 12:38 am
KS4 didn't "fail" because of the lack of an encounter system. It struggled because the pieces were expensive AND DF failed to product pictures of what you could make with a combination of the packs. Customers (new and old alike) struggled to conceptualize what could be built.
I get what you are saying but personally I could see what I could build just fine and could afford it, I just did not want a castle all that much so I got very little castle stuff. Now the mountain peices were great, I was all in for 3 full sets plus 4 add-ons.
Oh, I agree wholeheartedly. I ordered what I wanted, I knew what I wanted. I purchased a lot of castles and felt it was easy to conceptualize. But there were MANY who complained they couldn't and I don't want to malign their experience.
