Ruins, cont.
scott102303
Re: Ruins, cont.
Post by scott102303 » Mon May 13, 2019 4:43 pm
I can see that - I am likely also going to go in for some smaller pieces for Axe N Shield, but was debating whether I would attempt to setup my own larger layer cake setups with plexiglass. I'm not sure about how helpful the layers would be in play - they are certainly impressive to look at.
Re: Ruins, cont.
Post by zenako » Mon May 13, 2019 4:22 pm
scott102303 wrote:
Mon May 13, 2019 10:53 am
I was thinking about getting a couple big plexiglass sheets to do layer cake builds - what thickness do you think is minimum to support its own weight with a reasonable amount of supports? I am leaning away from the Axe N Shield solutions for such at this time and doing my own thing. Thanks.
My sheets are 1/4" thick, but they are also large ~3x4 and as such rather inconvenient for a smaller feature, which is why I am sticking with a modest AxeNShield buy. I do not have any "elegant" way to support the higher tiers at this point, hence the cardboard boxes. For sure they are cheap, but they also completely block actual sights lines if you want players to be able to see under the top tier.
thebigteacher
Re: Ruins, cont.
Post by thebigteacher » Mon May 13, 2019 1:06 pm
Lots of interesting ideas, keep them coming.
Re: Ruins, cont.
Post by Oldent » Mon May 13, 2019 11:46 am
I do not know. I have read 1/4 inch. I have no experience with using ]clear layer cake. I find that layer cake style builds take more play space than I have.You have to have a place to put the layers during play. My game room is too small for more than one table.
If you build something like Invincible Overlords table,you should not have the same problem.
scott102303
Re: Ruins, cont.
Post by scott102303 » Mon May 13, 2019 10:53 am
Re: Ruins, cont.
Post by zenako » Mon May 13, 2019 9:14 am
You can also see the plexiglass sheet I was using for the necro complex, sitting on some USPS Priority Mail boxes I folded up for this setting.
(I had an area under the plexiglass sheet where the water flowed down and into the center of the ruined fort that could also be examined. That was the stream in the middle of the fort. I would lift off the entire upper complex in one move (with some help) to reveal that later.)
Having a large 5'x10' table setting lets me create these large settings, which I enjoy. It also lets the play flow without any real interruption once we begin the session since I don't have to break anything down or build it up.
Re: Ruins, cont.
Post by zenako » Mon May 13, 2019 9:04 am
The Necromancer attached to that orc brigade had been very very busy creating his new troops in the old mountain complex. There were lots of source material from the nearby battles. I have a lot of undead minis...
Necro Warehouse Overview
Necro Warehouse Overview.jpg (100.54 KiB) Viewed 492 times
Necro Warehouse part1
Necro Warehouse part1.jpg (132.78 KiB) Viewed 492 times
Necro Warehouse part2
Necro Warehouse part2.jpg (114.19 KiB) Viewed 492 times
Necro Warehouse part3
Necro Warehouse part3.jpg (105.36 KiB) Viewed 492 times
Necro Warehouse part4
Necro Warehouse part4.jpg (124.97 KiB) Viewed 492 times
Re: Ruins, cont.
Post by zenako » Mon May 13, 2019 8:57 am
Here are some more shots I found of a later version of that ruined fort (and complex in the mountain behind it.
The Overview with Necro complex behind
The Overview with Necro complex behind.jpg (87.56 KiB) Viewed 489 times
Ruined area inside fort view 1
Ruined area inside fort view 1.jpg (80.86 KiB) Viewed 489 times
Ruined area inside fort view 2
Ruined area inside fort view 2.jpg (77.21 KiB) Viewed 489 times
Re: Ruins, cont.
Post by dice4hire » Mon May 13, 2019 8:49 am
I like all of those pics RB, A nice selection of ruined goodness.
Re: Ruins, cont.
Post by zenako » Mon May 13, 2019 8:42 am
Yeah RB, picture three is the kind of place you might come across in the wilderness that was abandoned or destroyed a long time ago. From a gaming perspective, lots of cover and hiding places, and makes for a more interesting encounter than an open field or plain woods.
