I'm Just Going to Leave This Here...
Re: I'm Just Going to Leave This Here...
Post by pacarat » Sat Feb 15, 2020 9:37 am
seriously...we’re talking about floating dwarvenite?
what’s next?
mad is right... :lol:
Post by zenako » Sat Feb 15, 2020 8:27 am
I suspect a nice line of "rubber cement" would do the trick and that should be something that could be removed without too much trouble later if needed. Even still, the weight of the boat might exceed the buoyancy of it and render any "pitch' being pointless and it may ride so low that the gunwales are below the surface.
Post by kodiakbear » Fri Feb 14, 2020 11:56 pm
Fri Feb 14, 2020 8:50 pm
the fit is not tight enough to be watertight?
With the weight of Dwarvenite I doubt it ever could be tight enough with out something to act as the pitch.
Post by dice4hire » Fri Feb 14, 2020 11:31 pm
Much better than tar, I assume.
Post by William » Fri Feb 14, 2020 11:25 pm
Isn't that why they invented Green Stuff chinking? ;)
Post by dice4hire » Fri Feb 14, 2020 8:50 pm
Post by kodiakbear » Fri Feb 14, 2020 8:38 pm
Some one should Elmer's glue it together and find out.
period3
Post by period3 » Fri Feb 14, 2020 7:35 pm
Has anyone tested if the DF boat floats? They advertise stuff like "working mangonel" and "working trebuchet". The fact that this was not advertised as "working boat" has me suspicious.
Post by GODofwar » Fri Feb 14, 2020 5:09 pm
Y'all are mad. Quite mad.
Totus KS Delenda Sunt, including the rumored but unlikely KS7
Post by dice4hire » Fri Feb 14, 2020 4:15 pm
The square boat does look interesting.
