PIECES - TEARDROP INSERTS
Post by JenneyOC » Tue Aug 11, 2020 4:46 am
Q: The Huge Rocky Hummock has a teardrop insert, but the graphic makes it appear as though the hummock is deeper than what the insert expects. Will there be a support for the insert, or is it an illusion, or are you supposed to jam the insert in and hope no-one steps too boldly on it?
A: They can be placed above grade on top of the teardrop hole, or inserted underneath to sit more flush, or be used on its own as a scatter piece.
Q: Could someone ask Nate to demo the Huge Rocky Hummock with an insert added from below? It looks to be too tall to hold the insert steadily. It feels like there should be an insert support…
A: There will be a foam insert to place underneath the teardrop insert to hold it up and in place.
Re: PIECES - TEARDROP INSERTS
Post by JenneyOC » Thu Aug 13, 2020 1:24 am
Q: Are these "tear drop inserts" compatible with/same shape as earlier inserts from caverns deep and dungeon of doom? I'm thinking of the spikes, eggs, etc
A: (Elye) They are not the same size as the Burrows inserts. (They're larger, and designed to also work as standalone pieces - so you can fit them in a hole in one of the swamp or forest tiles, or use them as freestanding scatter.) But we do also have a teardrop insert that is an adapter piece into which you can fit any of the Burrows inserts, so you can have the best of both worlds.
Post by JenneyOC » Wed Aug 19, 2020 1:09 am
Q: Q: What is the size on the wyvern nest?
A: It's about the size of a teardrop insert -- roughly a 2"x3" oval
A: (Elye) Among other things, it nestles very nicely onto the Wyverstone Platform and also sits well on the driftstones
