Is the pole peg the same as a small trunk peg?
Jenney will answer questions in the Codex Valoria Wildlands.
You may carry on discussions in the Kickstarter 7 Discussion Forums.
Mitch
Post by Mitch » Thu Aug 27, 2020 9:39 pm
Hiya Knightess. Is the thickness of a pole peg the same as a small trunk peg? For example, can a dead snag or rotten hole stump topper fit into a mossy rock mound or tiny hummock?
Re: Is the pole peg the same as a small trunk peg?
Post by JenneyOC » Fri Aug 28, 2020 5:19 pm
A: (Tyler) No. The Pole Peg is set at a 5/64 size, whereas the trunk pegs are set at a 9/64 size. The trunk pegs used are the same as the CBS system, so you COULD make it fit on a stone or tudor floor if you wanted. On the other hand, the Pole peg and the Paired pegs are the same size though.
A: (Elye) You could put a pole accessory in a stump, but it would fit loosely.
Return to “Ask the Knightess”
