Rock Breaker Bill's Not-So Ancient Stepwell
Re: Rock Breaker Bill's Not-So Ancient Stepwell
Post by William » Wed Sep 11, 2019 11:22 pm
Thank you RB.
On the other subject -
I found out Imgur changed last year and removed their "Album" sharing functions, due to privacy concerns. Hmmm?
Post on another forum (found in a search) I didn't even look what the forum is about. Worlds of Warships, I guess.
I'm holding off on this project for a while, because I need a break.
I may or may not take it to the next stage. :?:
Post by Rabbit Burner » Tue Sep 10, 2019 8:24 am
Thanks William :)
So when you built something big and cool - your first thought was......
'I want to make it bigger and throw more cool at it'
and voila one Very Cool EPIC build
Very nice job :D
Fab to see the evolution.
Fri Sep 06, 2019 7:41 pm
It's cool to see what makes the difference between a really good build (these pics) and an EPIC build (your final ones).
What AS said too :)
Post by William » Mon Sep 09, 2019 4:04 pm
Thanks, but trying to go back and repair those didn't work, so I'll try again tonight.
Any idea how to link a whole Album, there are hundreds of pictures in there.
Linking each picture would take me months. ;)
After a search, I see that Imgur has changed the pull down menu where you go to your own pictures. It used to have another Album category back in 2016 (per article on Embeding on other sites). So maybe one by one is it. :?:
Post by astolat » Mon Sep 09, 2019 3:54 pm
Mon Sep 09, 2019 6:51 am
This is a test of the Imgur broadcast system.
https://imgur.com/BaQbTUQ
https://imgur.com/w2Tas0i
https://imgur.com/KI9jSDF
I have dropped over a quarter of the 800+ Version 3 pics, all V-2 and all V-1 pictures on my Imgur account in three separate albums. Now, how do I link whole Albums? ;) :)
EDIT - Links only? ... Hmmm,... O.K. I guess I need to know how to link/show the pictures too? I feel like an idiot about all this computer stuff, because I know I've done it in the past. But,... HELP?
William, you need to click on the photo to open the full size image, then right-click and "copy image address" and then put that direct image link here inside [ img ] [ /img ] tags (without the spaces).
EG, this is the result of [ img ]https://i.imgur.com/w2Tas0i.jpg[ /img ]
(ETA: and then anyone can right-click on the image and open the full high-res image in a separate window and download or zoom in.)
Post by William » Mon Sep 09, 2019 3:50 pm
astolat wrote:
Tue Sep 03, 2019 1:01 pm
William, this is completely beyond epic, ... :D
And if by any chance you could post higher-res photos somewhere, I would love to look at it blown up across my entire screen.
I would do this, but as previous post suggests, I need some HELP from a more competent Imgur user. :D
Post by William » Mon Sep 09, 2019 6:51 am
[ img ]https://imgur.com/BaQbTUQ [ /img ]
[ img ]https://imgur.com/w2Tas0i [ /img ]
[ img ]https://imgur.com/KI9jSDF [ /img ]
EDIT 2 - doing that to these three.
EDIT 3 - Guess I can't repair those, so I'll try another group tonight.
Any idea how to post a link to an album?
EDIT Again for test.
https://imgur.com/5QTWlNc
https://imgur.com/2RUtgxc
https://imgur.com/Jx4w3yw
https://imgur.com/gw2C6f5
https://imgur.com/5OWzqRy
If you go there the large version should open?
Post by Arcarius2001 » Sun Sep 08, 2019 8:01 pm
Tue Sep 03, 2019 8:51 am
thebigteacher wrote:
Tue Sep 03, 2019 8:42 am
I bow to your awesomeness! How much resin and what type did you use? Did you have any curing issues? Wow, this is just exceptional.
None, it's a 3'x4' sheet of 1/8" plexyglass (it spans past both sides almost a foot) and a green colored cellophane sheet (see-thru wrapping paper) set on top. That's it.
Thanks - no bowing necessary. ;)
Freaking ingenious!!!
This is one of the most creative builds that I have ever seen, and probably the most visually striking. Truly an epic example of what you can do with Dwarven Forge. 👏 bravo!
Post by William » Sun Sep 08, 2019 6:44 am
Hey everyone (who's interested),
I'm about to make some alterations to this build this week, but I'm wondering if there are any areas of the layout that I didn't get enough pictures shown/posted. I think I missed a lot of the Woodland Maze shots by the Wormtongue statue, so I'll get some of those. I have removed the miniatures, so any new pictures will look like the area has been abandoned, unless I add some for the shots you request.
Any other areas you want pictures of?
I also might try another video, taken as if sitting in a boat in the middle of the well spinning slowly around.
Any ideas there too?
Ask soon (I really mean fairly soon, not a Nate ((or lately, my)) kind-of 'soon'), before I change it. ;)
Post by William » Sun Sep 08, 2019 3:50 am
Thanks CT. :)
I was just about to drop these when I saw your comment.
MORE Water Pictures... Funny you spoke about it.
ASW v3 - 101.JPG (74.07 KiB) Viewed 872 times
ASW v3 - 102.JPG (74.51 KiB) Viewed 872 times
ASW v3 - 103.JPG (78.45 KiB) Viewed 872 times
ASW v3 - 104.JPG (118.36 KiB) Viewed 872 times
ASW v3 - 105.JPG (90.43 KiB) Viewed 872 times
ASW v3 - 106.JPG (105.53 KiB) Viewed 872 times
ASW v3 - 107.JPG (85.95 KiB) Viewed 872 times
ASW v3 - 108.JPG (89.58 KiB) Viewed 872 times
ASW v3 - 109.JPG (101.21 KiB) Viewed 872 times
ASW v3 - 110.JPG (101.18 KiB) Viewed 872 times
ASW v3 - 111.JPG (81.74 KiB) Viewed 872 times
ASW v3 - 112.JPG (57.05 KiB) Viewed 872 times
ASW v3 - 113.JPG (65.2 KiB) Viewed 872 times
ASW v3 - 114.JPG (85.42 KiB) Viewed 872 times
ASW v3 - 115.JPG (108.22 KiB) Viewed 872 times
ASW v3 - 116.JPG (103.43 KiB) Viewed 872 times
ASW v3 - 117.JPG (81.28 KiB) Viewed 872 times
ASW v3 - 118.JPG (106.75 KiB) Viewed 872 times
ASW v3 - 119.JPG (109.32 KiB) Viewed 872 times
ASW v3 - 120.JPG (131.84 KiB) Viewed 872 times
ASW v3 - 121.JPG (110.78 KiB) Viewed 872 times
ASW v3 - 122.JPG (118.24 KiB) Viewed 872 times
ASW v3 - 123.JPG (125.54 KiB) Viewed 872 times
ASW v3 - 124.JPG (99.41 KiB) Viewed 872 times
ASW v3 - 125.JPG (105.03 KiB) Viewed 872 times
I'll try to upload the higher def pics in next few days, always after midnight. ;)
ChrilleT
Post by ChrilleT » Sun Sep 08, 2019 3:30 am
Amazing build! You made the water look very cool and overall cool build.
